Canon PIXMA iP2000 InkJet Printer
Problem for Canon PIXMA iP2000 InkJet Printer
Am getting an error - ink absorber is full - what
By merlin608 on Nov 06, 2009
am getting an error - ink absorber is full - what is the solution to fix this problem
Solution #1
posted on Nov 06, 2009
Not Rated)
greg_margo
Rank: Guru  Computer Hardware  Expert
Rating: 91%, 697 votes
There are basically 3 solutions to your problem.
  1. Reset the printer to clear the fault
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  • Turn the printer back on.
If this is unsuccessful, then the machine needs to be repaired. Canon does not recommend repairing/replacing the waste ink tank yourself. If you choose to make the repair yourself the waste ink tank is actually a sponge that absorbs waste ink. You can either purchase a replacement pad/sponge and install it or thoroughly wash out the old one and let it completely dry prior to reinstalling it.
There is also a reset code to Resume printer and temporarily remove the error as follows:
1 - press resume button and then press power button
2 - realese the resume button and press 2 more times then realese both
3 - press and release resume 4 times and power 2 times
I hope you find this answer useful and that is solves your problem. All the best!
Greg
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA iP2000 InkJet
Questions and Unsolved Problems for Canon PIXMA iP2000 InkJet
Do you recommend Canon PIXMA iP2000 InkJet Printer?
Answer
Answer
Power light keeps flashing red and then orange. The middle cartridge holder under the top lid when... (More)
Answer
i have replaced both ink cartridges in my cannon pixma ip 2000 but it will not print colour only... (More)
Answer
ip 2000 on button flashes green then orange , wont operate !
Answer
The power button has just stopped functioning. It does not stay on when pressed.
Answer
i am trying to attatch my printer it is a canon ip2000 to a eee pc notepad, but it will not.. any... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PIXMA iP2000 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
