Maytag LegacyT Top-Load Washer
Problem for Maytag LegacyT Top-Load Washer
The washing machine walks at times. It doesn't
By cobber705 on Nov 06, 2009
The washing machine walks at times. It doesn't seem to stop running or adjust itself. just keeps walking till I manually re adjust the load. Is there a sensor that could be bad?
Solution #1
posted on Nov 06, 2009
Not Rated)
slosmogman
Rank: Guru
Rating: 86%, 370 votes
Remove the housing. Most likely a balance spring came loose. There are three of them. Simple fix if you can remove the cover
Was this helpful?
Yes
No
Popular Solutions for Maytag LegacyT Top-Load Washer
Questions and Unsolved Problems for Maytag LegacyT Top-Load Washer
Do you recommend Maytag LegacyT Top-Load Washer?
Answer
Answer
WJSR2070B2WW AGITATOR REMOVAL NOISY IN SPIN . AGITATOR SPINS BUT TUB DOESN'T.
Answer
The water is leaking out of the door
Answer
use to be very quiet now very noisy what can I do to quit this thing
Answer
washer takes coins and says select cycle will not start unplug machine then plugin then will start
Answer
I have a maytag mah 3000 washer which operates normally throughout entire cycle .However when it has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
