Roper RS25AEXLQ Side by Side Refrigerator
Problem for Roper RS25AEXLQ Side by Side Refrigerator
What does energy saver do ?
By jmgold1n1 on Nov 06, 2009
what does energy saver do ?
Best Solution
posted on Nov 06, 2009
Very Helpful)
tbirdfan1
Rank: Guru
Rating: 89%, 931 votes
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
localwonder
Rank: Guru  Refrigerators  Expert
Rating: 92%, 2978 votes
The energy saver option is used to provide less draw on the electricity current, in return, reducing your monthly electrical bill, while producing an optimal cooling cycle, and proper cycling intervals of the compressor unit, as well. This option, or state of operation, will reduce the amount of your monthly electrical bill by 1/3, if used correctly. It will, also, increase the life of the compressor assembly as well, by shortening the running time.
This is a great feature, and can be beneficial.
Was this helpful?
Yes
No
Popular Solutions for Roper RS25AEXLQ Side by Side
Questions and Unsolved Problems for Roper RS25AEXLQ Side by Side
Do you recommend Roper RS25AEXLQ Side by Side Refrigerator?
Answer
Answer
Roper freezer is leaking and freezing in bottom of freezer. How do I find the drain system and... (More)
Answer
my ice maker doesn't want to reset even though the water does still work. lever for reset does seem... (More)
Answer
I have a roper RS25AWXAW00 sid e by side and the ice maker just keeps cycling, and is not making... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
