Question about NetGear DG834G Router
NetGear DG834GT I havet the GT model of above mentioned router and having problems connecting my iTouch to it. The iTouch finds the Sky router and prompts password which I am typing in correctly - have checked it loads and it is correct (my wireless laptop connects fine) but I keep getting prompted to re-enter the password for router or says it is incorrect Any suggestiong please?
  • 537 Answers
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Posted on Jan 05, 2008
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My wifi network is on but my itouch isnt seeing it why is that
check your itouch to see if you see the router.
Follow these instruction to set up wifi device.
.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the ITouch up in the router by WEP/WPA KEY or MAC address.
6.Note router name you are connecting to.
This is for all routers to set up wirelessly.
Aug 16, 2010 | NetGear DG834G Router
Does the netgear dg834g work with sky broadband
Thats an ADSL modem/router, so would be used via the telephone line In fact this is the standard router often supplied by SKY DG834GT
theres a number of answers here on the sky site for setting up a router http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=25126ec2-287b-4e70-9014-967423a8dbf1
sky users tutorial for setting up a router http://www.skyuser.co.uk/forum/view-router.html
Mar 19, 2010 | NetGear DG834G Router
Netgear Wireless - G USB 2.0 Adapter
Hello, Joe.
Assuming Sky doesn't prevent access to non-sky internet services (if they did something crazy like that, it is most likely a Sky specific firmware that was put on the router, which would mean you need to put the Netgear firmware back on), I would say you have something set up wrong.
Can you get to the internet through a wired connection? If so, wireless is probably configured wrong. If you can log into the router, that would give you an easy way to find out how thw wireless is set up. goto your web browser (on a wired connection to the router) and type "192.168.1.1" or "192.168.0.1" When prompted, type in your username and password (probably, "admin" and "sky" or "admin" and "admin").
If you can't log into the router then you'll have to try and figure out the connection through trial and error. When you were with Sky and the tech installed your router, did he/she give you an encryption key to use when you connected? If so, I would try "shared WEP" first (providing the WEP key given to you). If that doesn't work, try WPA-PSK.
Hope this helps,
Bill
Sep 03, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Need to change the MTU for my router
your router got a default IP address... find it...
Jun 16, 2009 | NetGear WGR614 Wireless Router
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Netgear ADSL super G wireless router
I hope this will help you to solve the problem...
http://www.jjclements.co.uk/index.php/2007/09/30/sky-router-dg834gt-unlock/
Apr 27, 2008 | Computers & Internet
Netgear router dg834gt
Have look in the router settings for the actual internet connection speeds, as these are a more true reading than the speed check as the speeds can vary at different times of the day and 2 or 3 speed checks can bring different results. your actual connection speed that is showing in the routers settings is the connection you are getting from your ISP. If you are with BT they usually recommend using their latest routers, why i'm not sure, as the only thing i have noted is that the MTU is set at 1500 (Maximum Transmition Units)and in other routers the MTU is automatically set at 1493, so look for the MTU setting and up it if necassary, but not above 1500, also double check all the settings, even put the bt router back in and see if speeds improve, if, you know the BT router is set up purposly for faster connection speeds. Also try checking your speed at a speed test site at a quieter time of day, you will also see different speed check sites give you different speed results.
Jun 18, 2007 | NetGear DG834G Router
Sky branded Netgear DG834GT router
OK - it can be very simple to do, but took me two hours to work out ;-)
Google for all the info you can.
Download the recovery utility from Netgear.
Download the latest OS from Netgear.
Flash the router with the OS.
Enter the router config panel.
Change the Sky login and password to the ones given you by your ISP.
That should be that.
Keep trying: I did, I'm no expert, and I got there.
Do everything you can to a*sf*ck Murdoch and his company.
Apr 02, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
113 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
