whenever you use the same phone line that is connected to the priner for the fax and you use the same line for other use. then it shows phone off the hook.. you dont need to worrry about that. that is pretty normal.
there is no problem.
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet 7310 All-In-One
i replaced my print cartriges, at first it stated the color ink was bad, so I replaced it again and...
(More)
i replaced my print cartriges, at first it stated the color ink was bad, so I replaced it again and now it keep saying remove print cartridges.
Remove display "Genuine HP Print Cartridge installed" every time I print -- 3 display...
(More)
Remove display "Genuine HP Print Cartridge installed" every time I print -- 3 display messages pop up
(This software cannot be installed using the 'Run as...' command. The installation cannot continue...
(More)
(This software cannot be installed using the 'Run as...' command. The installation cannot continue until this is resolved. Required Action: Click Cancel to exit this software installation. Log off and then log on as a user with administrator privileges. (Contact your system administrator for more information.) If there is no system administrator, have the primary user of this computer install the software. Restart the installation by removing and re-inserting this installation CD)I HAVE TRIED THIS NUMEORUS TIMES,STILL NOTHING.I'M USING THE DISK THAT CAME WITH PRINTER. PLEASE HELP ME.
