GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Problem for GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator...
I have a 7 year old GE refrigerator
By cslatham on Nov 06, 2009
I have a 7 year old GE refrigerator (top mounted freezer) that seems to stay in defrost too long-- everything in the freezer defrosts, the ice cubes start to melt, the ice cream gets soft, etc. Food in the fridge doesn't keep well. I have spoiled milk before the expiration date. Later everything in the freezer has frozen back solid as a rock.Could it be the defrost timer? Is this something I can replace myself?
Solution #1
posted on Nov 06, 2009
Not Rated)
woodchuck789
Rank: Guru  GE Refrigerators  Expert
Rating: 91%, 581 votes
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Was this helpful?
Yes
No
Popular Solutions for GE J Series 18.2 cu. ft. Top
Questions and Unsolved Problems for GE J Series 18.2 cu. ft. Top
Do you recommend GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW?
Answer
Answer
refrigerator runs almost constantely just shuts off for a short time a goes back on and runs for a... (More)
Answer
Six year old, GE Frost free 18.2 Cft. Compressor does not turn on but fan runs
Answer
my ge refrigerator will not get below 57 degrees, needs to be 41degrees or colder, but the freezer... (More)
Answer
neither the fridge nor the freezer are staying cold. The side by side unit keeps running but not... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE J Series 18.2 cu. ft. Top...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1226
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
