Humidifiers
Generic problem for all Humidifiers
Bionaire BCM645 Cool Mist Humidifier leaking water
shared by 4 users
posted by Laurie88 on Jan 05, 2008
I fill the 4 gallon tank with water and place it in the unit. No problem for about 20 minutes and then you can see water leaking out of the sides of the bottom. It seems to be overfilled. How can I stop this from leaking.
Thanks
Laurie
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by Guest on Nov 19, 2008
this unit ****!!!
Posted by marina228 on Nov 05, 2008
I have had my humidifier for only 5 months and it has leaked twice. The second time I watched it closely to see why. There are no hairline cracks that I can visualize. The first night of running went smoothly with no problems. The next morning though the humidifier was completely empty and the desk it was setting on and the floor was drenched!!! I cannot figure out why it is dumping out like it is and I am getting frustrated!!!!!
Posted by Shanster on Feb 05, 2008
I am having the same problem - water dumps out all over the floor from the sides and bottom of the unit when we refill the tank. There is a tiny crack in the tank, but we have patched it with tape and glue, and the water is not leaking from there.
Best Solution
posted on Feb 16, 2008
FixYa! (100)
ScottSwan
Rank:Wiz Wiz
Rating: 85%, 35 votes
Same here
Comment posted on Feb 16, 2008
Oops, I didn't think that would actually post.
Anyway, yea, I've been trying to figure out why this BMC630 randomly leaks. After reading some posts here I took a good look at the water tank near the handle and sure enough there are 2ea 1/2" hairline cracks in the clear plastic on the opposite side of the handle. They aren't cracked enough to let water leak out if I hold it upside down - full of water, but I bet they are just enough to let air in from the top slowly, allowing the bottom to over fill.
Repair wouldn't be easy as this tank is going to get wet from time to time when we fill it, so tape or glue would probably weaken over time.
I'm also not thrilled with the way the wicks work (they are always dry except for the bottom) so I think we will be returning this one and get something different.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Bionaire BCM645 Cool Mist Humidifier leaking water:
I don't want to Accept this solution
Solution #2
posted on Jan 05, 2008
Not Rated (0)
mikemilw
Rank:Wiz Wiz
Rating: 84%, 236 votes
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Thank You!
Can you Help with these Humidifiers problems?
Aprilaire 600 Humidifier
I have wired up the Aprilaire 700 and when I turn it up to...
Hunter 33201 Humidifier
Our unit worked fine for the first few months, but now...
Vornado HU1-0016-14 Humidifier
The unit is plugged in and the green light will come on...
Tried to turn on my Hunter-33257 (only 1 yr old, cleaned...
Humidifiers
I have a Carrier Humidifier and the setting has two...
Loading problems.
Repair Service
Find Humidifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
