Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Start Deivce Relay
I have read this forum and found that the Start Device Relay has burned up. I have already ordered a new replacement part from Sears Parts on-line and it should be here Sat. 1/5/08. Fixya member, Rene Kirk asked "Does this normally burn out by itself or am I looking at another problem that causes it to short out?" The answer was from fmauka..."A normal tech check at this point, is to check ohm readings, short run motor and check current draw, ( to check motor run resistance) and if abnormal reading, then replace the condenser/compressor unit on warranty service..." I have also read on other web sites that I should check the ohms on the Start side/windings (between 1-5 omhs) and the Run side/windings (between 3-11 ohms). To be honest I have know idea how to do this and where to find the Start and Run windings. Please help...
  • salvadore ferrara Jan 05, 2008
    Thanks for the info. Mike. I do own a Volt/Ohm Meter and I am familiar with it enough that I would like the test my fridge. My model number is 106.53542300 a Kenmore Side by Side Unit. Now I have tested the wires supplying the relay and they tested 5 ohms. Your help is greatly appreciated.
    Thanks, Salvadore
  • salvadore ferrara Jan 09, 2008
    Mike,
    Thanks for all your help. Everything tested okay on the fridge and I got my parts in on Monday and the fridge is working great.
    Thanks,
    Salvadore
  • 283 Answers
Save it. What you want to know is, did the compressor cause the relay to fail or did the relay fail on its own? There has been a lot of discussion on this issue. One thing is irrefutable - PTCs normally run HOT. After years it's a wonder any solid state device holds up as long as they do. Fortunately by design the wafer crumbles and they usually fail open before passing current to the start winding. I've found only one case where the compressor was bad along with a PTC and even then I couldn't conclude the relay was the cause.
Posted on Jan 05, 2008
  • 290 Answers
The start and run windings are the electrical circuits inside the compressor. If you have a volt/ohm meter with an amp clamp it is good to check for shorts, resistance, and amp draw when replacing the relay. If you do not have a meter and don't expect to need one for anything except this repair then just replace the relay and see what happens. If it fails within a short time, then you probably need a technician that is familiar with the model and factory specs to check it anyway.
We have seen a sharp rise in relay failures in the last few years. Most of the time, the relays fail on their own because they are built with cheaper material than in the past. They do not seem to hold up as well to power surges and fluctuations in voltage as older units did. The replacement relays we are recieving are supposed to be better according to the manufacturers.
I guess what I am saying is don't overcomplicate the repair. While I do occasionaly find other reasons causing a relay failure, the large majority of the time it is just the relay that needs replacing.
If you have a meter and are familiar with it, and want to check everything, post the complete model number from the fridge and I will try to walk you through checking it.
I have posted this for information only, not for a rating. You are free to rate it as you like, but if you don't want to rate it as a fixya then I ask for you not to rate it at all since anything else will drop my rating.
Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 05, 2008
    Pop off the grill in the front of the machine. There should be two tech sheets stuck into slots on the back side of the grill. One is for the icemaker, the other is for the rest of the fridge. This sheet should have your specs on it. There is no repair manual published for these units, the only model specific info you can get is on this sheet.
    First check your compressor windings to ground. There should be no continuity between the compressor housing and any of the terminals on the compressor.
    You have 3 terminals on the compressor. The bottom one is usually common, the upper left is usually start, the upper right is usually run. If yours is different you will figure it out whenyou check it.
    From run to common you should have about 2-3 ohms.
    From start to common you should have about 5-6 ohms.
    The start winding is usually about twice the resistance of the run winding.
    Add the readings together from the run and start windings and that is what you should get checking between run and start terminals.
    If you can check capacitence with your meter, check the capacitor. The specs for it should be printed on it, usually 13- 15uf.
    If you are good to this point, install the relay and hook up the wires. Put your amp clamp around the wire coming from the common terminal of the relay, usually red. Plug the fridge in and watch the amp draw. At start up it will spike 14-18 amps. It should drop quickly to around 2 amps usually.
    The compressor should now be running as well as the condenser fan motor. Open the freezer door and look at the bottom of the evaporator coil that you can see through the rear wall of the freezer. it should start frosting over.
    If all is well so far, reinstall the cover on the back of the unit, close the doors and let it cool. You should see freezing temperatures in the freezer in a few hours. Allow 12-24 hours before loading all your food back in to let the box get back down to temp.
    Post back if you have questions.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 07, 2008
    Salvadore,
    Just wanted to follow up on your fridge and see if you got it going.
    Thanks/Mike
Hi, I currently purchased, Cisco 1941/K9 with 2 onboard GE, 2 EHWIC slots, 1 ISM slot, 256MB CF default, 512MB DRAM default, IP Base. Questions 1. With IP Base License, will I be able to run Frame Relay?...
1) FR should be supported in IPBase license
>>Offers features found in IPBase IOS image on ISR 1800,2800 and 3800 + Flexible Netflow + IPV6 parity for IPV4 features present in IPBase.
note X.25 is mentioned in the first table FR it isn't.
2) You need to purchase a PAK and you should be able to generate the DATA license SAL from the portal following the instructions (there are also other methods described in the document)
3) you need SEC for IPSec VPN it means another PAK to buy
4) yes you can install all of the additional licenses in a single device
5) yes, they build on IP Base so you add features without removing any
6) no, the new device will be already with the correct licences from factory
>> On each shipped device IPBase software activation key is installed by default. Additional keys are installed by manufacturing depending on the customer order.
7) yes with the UC PAK
Hope to help
Mar 24, 2015 | Cisco Computers & Internet
Computer will not recognise cd discs for burning will recognise dvd discs computer: hp a1350a media center
Just click below for information;
s.gif » CD or DVD Drive is not Detected (Windows 98, ME, or XP)
Is RecordNow or Easy CD Creator not recognizing the writable CD or DVD drive in your PC? Use this document to resolve this issue. s.gif » Drive Cannot Write to Writable Discs (Windows 98, ME, XP)
Getting errors while creating a CD? This may help? s.gif » Creating a Music CD
How to create an audio CD. s.gif » Drive Cannot Read Purchased Discs in Windows 98, ME, and XP
Putting in a game disc does nothing? Use this document to resolve the issue or find out if the drive is bad. s.gif » Enabling or Disabling Autoplay, Starting CDs and DVDs Automatically
How to make discs start automatically when they are inserted into the CD or DVD drive. s.gif » Troubleshooting System Recovery Problems in Windows XP
If you are having problems using the HP Recovery process on your Windows XP computer, this document will probably help. s.gif » Obtaining a Recovery CD or DVD set
Learn how you can get recovery discs for your HP or Compaq desktop PC. s.gif » Installing or Replacing a CD, CDRW, or DVD Drive
This document provides step-by-step instructions to install, remove, or replace a CD or DVD drive. s.gif » Opening a Stuck CD or DVD Drive Tray
Drive door stuck? Use this document for several methods to try that open the CD or DVD door. s.gif » Computer Starts to Black Screen With Only a White Arrow
If your computer always starts at a blank screen with only a mouse pointer, use this document to restore the file lsass.exe.
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Computers & Internet
Refrigerator clicks then hums but does not get the compressor going. Bad compressor - how do you test if starter switch or compressor?
The clicking sound you hear is the overload relay trying to start the compressor. The humming sound is the compressor. Purchase a overload relay kit. Unplug the unit. Remove the bottom back cover. On the side of the compressor is a black box. Usually held on by hard wire clips. Remove the cover. Inspect for burned wires. Take note of the relay components. Remove them and lay them out in the order and orientation in which they were removed. If you see burn marks on the you have a bad relay, also the white 'V' shaped component - shake it. If it rattles it is bad. Replace with the new overload. If everything looks good. With a multi-meter measure the Ohms across the three pins on the compressor. You will get One high reading. Across the other two you will get lower readings. The two lower readings when added together must equal the high reading. If they do not you have a bad compressor. To replace a compressor is a major repair. The cost is usually $600.00-$750.00.
Rule of thumb; "If the repair cost is 1/3 or more of your initial purchase price of the unit - Buy a new unit".
Oct 21, 2014 | Maytag Refrigerators
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Mar 27, 2013 | LG Ranges LRE30453ST 30 Inch Freestanding...
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
first you should go into the bios and set the boot order to make the CD drive first. On that same screen you need to make sure that the CD drive has been enables as a boot device. If you haven't already tried it make sue the disk you are using is clean and actually a bootable disk.
Dec 09, 2010 | Compaq Presario 700 470024-192 Notebook
Replaced start relay, still didnt help :(
It sounds like the Tech only did half his job and seen that the start device was burned up and called it that and didnt check the compressor or you got a bad start device or, you didnt put it on corectly or the thermostat in the refrigferator is off.
When you put the new start device on and you pluged the machine on, Did the condensor fan come on (the fan right by the commpressor ??)
If that fan came on and the compressor did not start.
the windings in the compressor could be bad and you will need a compressor for that machine.
Oct 08, 2009 | Maytag MSD2352KES Stainless Steel Side by...
Water not getting hot
I had the same problem and had it resolved by replacing the heater unit. I found out the heater was open (burned or deffective). I ordered the part (found in eBay) and replaced it by myself. I am not a technician or expert, I downloaded the service manual and tested the heater terminals while on test mode and discovered it was receiving voltage, but its circuit was open. I recommend you do this step before buying any parts, since I read in the forums that another possible failure is the PCB (main board), and in this case voltage is not sent to the heater. I hope it helps, good luck !
Nov 01, 2008 | Dishwashers
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
W55 Flash dead, E:91:01
I googled this error and found a few relevant links:
http://forums.dpreview.com/forums/read.asp?forum=1009&message=20161066
http://www.fixya.com/support/t427780-e_91_01
Jul 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Toshiba DVD-ROM SD 6012
Im sorry to tell you this my friend.. it seems I catch you a bad time but I suggest that you need to replace it with a new drive since CD/DVD writers has its life span limit.. Be careful in doing burn CD's especially if its in long hours since it tend to damage the lens of your drive because of too much heat that was prolonged in a long run.. If your'e using it as DVD ROM at the same time, I suggest that you must have another drive to minimize damage to your drives..
Feb 05, 2008 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
