I recently sent a broken paper back book cover through my washer. The book shredded during the wash cycle and I think it clogged something. It is now leaking from the bottom.
Hello, from the sound of things you have more than likely clogged the water pump, it will need the hose removing from it and cleaning out. Unless you have done this before yo may need to get a service technichian in to do the job. I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22422 Top Load Washer
The top of the spinning post in the middle of the tub now won't spin when washing (evidently...
(More)
The top of the spinning post in the middle of the tub now won't spin when washing (evidently disconnected from lower part of spinning post)?
I have a Kenmore Elite top loading washing machine. The machine stops in the middle of a cycle and...
(More)
I have a Kenmore Elite top loading washing machine. The machine stops in the middle of a cycle and shows code CA. When I try to run it so that the water will drain I then have water coming out of the bottom of the washer.
I have a front loader Kenmore Washer and cannot find the Screen Filter. It looks new in front but it...
(More)
I have a front loader Kenmore Washer and cannot find the Screen Filter. It looks new in front but it does not have the easy screen removal that looks like a gasoling car opening. I removed the excess water by lowering rubber after releasing a wire seal. So where is the screen filter, below inside the rubber or above where the water came from? And is it removeable?
It processes most the load then it reads LD on the display. I just moved in Sat. and this is the...
(More)
It processes most the load then it reads LD on the display. I just moved in Sat. and this is the type 580 kenmore elite oasis he. I tried it Sat. and it worked. I cannot find the manual online for the model 110.27062603
