Hunter Fan Company 5/1/1 Programmable Thermostat
Error Message RE CO on Indiglo
shared by 4 users
posted by section1 on Jan 05, 2008
I woke up this morning and the indiglo was flashing RE CO. The other problem is that in the winter the heater never reaches the desired temp. I have the thermostat set for 66 but most of the time it will be 60 in the house and the heater will be off.
Thank you for your help.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Posted by cccade on Nov 30, 2008
mine does the same thing, how do i fix this problem?
Posted by debh3307 on Nov 26, 2008
I have one of these tstats also and I have to say I hate it. I can never get it warm in my house. I have it set at 73 but the temp in here is always in the low 60's. I cant figure out how to get the furnace to turn on and stay on. I also have to rec message flashing and cant seem to reset that. I live in a northern state the temps here are getting down to the teens at night and very cold in my house. I have reset this many times but still cant seem to keep my furnace running.
Posted by Guest on Jan 25, 2008
Same problem what does this error mean?
Best Solution
posted on Jan 29, 2008
FixYa! (100)
ktquinn
Rank:Guru Guru
Rating: 87%, 64 votes
look on the back of the tstat their should be a switch marked recovery mode try turning it off and see if it helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Error Message RE CO on Indiglo:
I don't want to Accept this solution
Best Solution
posted on Oct 02, 2008
Helpful (85)
Oyasumi
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Thank You!
Solution #3
posted on Sep 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
so I just checked mine and it was already ont RECOVERY to begin with, so not sure that will help.
Thank You!
Solution #4
posted on Sep 03, 2008
Not Rated (0)
lennard-jean
Rating: 0%, 0 votes
do i leave the switch turn off or do i turn the switch back on.
Thank You!
Can you Help with these Electric Fans problems?
Hunter Fan Company 5/1/1 Programmable...
I cannot get my thernostat to work. I changed the...
removed honeywell round now new on which is pure pro...
programable thermostat error
i have a hunter programmable thermostat, i m trying to...
I want to hook up my Hunter 42999b thermostat, but I want...
Loading problems.
Repair Service
Find Electric Fan Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
