Question about Epson Stylus Photo R1800 InkJet Printer
Magenta light blinking on epson r1800e....
I have an epson r1800 printer with a bulk in system installed, everything was working fine until my ink run out. i ave replaced the ink and it seems it does not recognise that the ink has been replaced....i want to know if i need to reset it manually, i have even bought a new cis system and it still says the ink is empty, is there anythin i can do...i really will appreciate some help on this issu
  • acepilot Jan 25, 2008
    same problem. any way to override
Hi, i had the same problem with my r1800. It said that the ink were not genuine and after about 1000 trys turning back on and off it eventually decided it didn't recognize any of the inks.
I had ti take it to the menders and they told me it was something to do with the sensors in the nozzles or something. Anyway i had to get it replaced.
I am now on my third r1800, all with the same problem luckily i got them all within the warranty. Good luck.
Posted on Jan 19, 2008
Read the manual, says something about turning off for 30 seconds and bac k on again will reset
Posted on Jan 13, 2008
I have inherited an Epson R1800 printer that guzzles magenta and cyan inks like crazy. Am I doing something wrong?
No, If you are printing any coloured output this will be normal depending on the actual colour content and what most people don't realise is that unless your text is pure black then it will be printed using the color carts as well and not the black ink cart.
Oct 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 paper and ink lights are blinking
See status monitor? Is service required? Reset waste ink, Find resetter at indoreset.blogspot.com
Jun 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 with magenta blinking ,and wont recognize the said ink
Hi-
Try reseating all the ink cartridge, make sure you have the right cartridge for each slot and make sure all are genuine epson in. try another magenta ink as well if you have a spare. if all fails call epson at 5622761300.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper and ink lights blinking - no power light flashing at all - can't do anything on our Epson R1800 printer... can you suggest something to try? have been doing a lot of head cleaning due to bad nozzle...
Try doing a printer check by doing the steps below. If it doesnt work, then try to call the printer manufacturer for more advanced solutions or information
  1. turn off the printer and disconnect it from computer
  2. place a plain sheet of paper
  3. press and hold down the paper feed button, then press and release the power button. Continue holding down the paper button until you see the power light flashes
  4. if it prints a test page it is working fine, the problem might be the computer settings, printer settings, software or printer application, or cables, otherwise the problem is the printer itself
Oct 13, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson r1800 both light flashing
try taking out the inks you have installed make sure that you hear a click on each of the inks when you install them. If the issue persists the printer may not recognizing the inks you have installed.
Jun 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
Ink is out eventhough there is ink in there!
Usually printer companies do not support refilled cart , as in this the problems lies with cart ,change to original cart or replace the defective cart .
May 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
Hi
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
