GE Profile JT952 Electric Double Oven
Problem for GE Profile JT952 Electric Double Oven
FO shows on led board for both ovens
By l2000mass on Nov 06, 2009
oven started to ring without any reason and an "error" blinking. Pressed off button. 5 mins later started again. Used trouble shoot by cutting circut breaker for 4 hours turned back on now ther is a FO on pannel. Holidays are approaching HELP!
Lea
Comments:
Nov 06, 2009
- What did you mean by EOC (clock). Should the whole pannel be replaced or just the clock????? To Vague Lea
Best Solution
posted on Nov 06, 2009
Very Helpful)
localwonder
Rank: Guru  GE Ovens & Ranges  Expert
Rating: 92%, 2861 votes
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Comments:
Nov 06, 2009
- EOC= Electronic Oven Control Board
Nov 06, 2009
- I apologize for the use of the abbreviation. The EOC is basically the main control board. The control panel is what the board will be mounted, or screwed onto. As stated above, most newer units will have an all-in-one control board, that incorporates the key pad, and main circuit board in a whole piece. if this is the case here, simply replace the entire EOC(Electronic Oven Control Board).
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Response was very quick and directions fairly simple except when abreviations were used. Had to question againg for full words for abreveations. " - l2000mass
Popular Solutions for GE Profile JT952 Electric
Questions and Unsolved Problems for GE Profile JT952 Electric
Do you recommend GE Profile JT952 Electric Double Oven?
Answer
Answer
I have removed my electric wall oven and cooktop and am replacing them with used westinghouse... (More)
Answer
I need directions on how to use the probe for my GE oven probe.
Answer
After cleaning oven, door would not close/lock...What to do?
Answer
ge profile double oven, model # jtp56bowlbb, appx. age 2000. push any button and number 6 comes up... (More)
Answer
What if anything had to be removed from the oven before starting the self-cleaning feature?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Ovens Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
