LG Direct Drive WM-16220FD loud vibration during spin cycle
Hi, I have a LG Direct Drive washing machine WM-16220FD which is now about 18 months old. Recently, during the spin cycle a loud vibration has started from the front left side as you look at it. This noise happens whether the machine is empty or full.
Any ideas what this could be?
Regards,
Nikki
  • Anonymous Mar 25, 2014
    Leak from underneath
  • Anonymous Mar 26, 2014
    3 days ago my machine got real loud during the spinning cycle then today the tub started bouncing of the side of the machine I took the front off of it and all the springs are still attached
    Sergeant:
  • 274 Answers
The pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • Jason Harris
    Jason Harris Jan 05, 2008
    if you need any more help just get back to me and i will be glad to help ok
6ya staff
SOURCE:
Spin cycle isnt spinning. it will spin slowly during rinse but not spin cycle
Are you receiving a "LE" error code on the display? If so, you'll possibly need a Hall sensor or Stator assembly replacement. If you have your units date of purchase, it will possibly fall under the 7 or 10 year warranty on the direct drive assembly which includes hall sensor/stator/ and the rotor.
You can refer to LG for service if you'd like.
Mar 07, 2011 | LG WM-2277HW Front Load Washer
Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The machine is level. shakes and loud during
you could have a broken shock but most of the time the spider gear is gone,the money it costs to fix it you could by a new washer,that will be up to you to decide
Oct 31, 2009 | LG WM-2277HW Front Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Loud noise when on spin cycle
hi the engineer probeply rejected agitator dogs problem sounds like he is right for the diagnosis on the bearings although it is very wired forthis problem on a new machine its probeply a defect bearing http://www.applianceaid.com/direct.html#agitating http://www.repairclinic.com/0047_11.asp good luck
Apr 26, 2006 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
976 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
