Whirlpool LER4634J Electric Dryer
Problem for Whirlpool LER4634J Electric Dryer
How do I replace the belt on a white westinghouse
By monabi on Nov 06, 2009
how do I replace the belt on a white westinghouse dryer, model #DG500EXW1
Solution #1
posted on Nov 07, 2009
Not Rated)
hunter19_46m
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 91%, 334 votes
LWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Whirlpool LER4634J Electric
Questions and Unsolved Problems for Whirlpool LER4634J Electric
Do you recommend Whirlpool LER4634J Electric Dryer?
Answer
Answer
i have a whirlpool tumble dryer awz3518, that has a flahing filter light on it, but the filter is... (More)
Answer
For the last several months the dryer doesnt stop when the door is opened. Now today it doesnt turn... (More)
Answer
when the dryer is running it sounds like the belt that turns the drum is slapping
Answer
the knits/gentle/low position does not provide low heat
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , AK
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
