HI. The inlet assembly is malfunctioning. The solenoid is stuck at this moment(Debris will build up,in return, causing the solenoid to stick. The valve can fail mechanically, as well). this will produce an uncontrollable flow of water, in to the manifold. Follow the procedure below to address this issue further.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
NOTE_ In most newer units, thee will be a third flow solenoid mounted near the ice maker assembly. Test this solenoid as well, if equipped.
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good...
(More)
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good or bad would be helpful. Thanks
i scarted up my cctv camera to tv and no picture could be seen and i also switched all av's -- power...
(More)
i scarted up my cctv camera to tv and no picture could be seen and i also switched all av's -- power to cctv proven as red light showed on the camera but no picture on tv
water dispenser will activate for approximately 5 secs. and dispense water without pushing on...
(More)
water dispenser will activate for approximately 5 secs. and dispense water without pushing on activating switch. Will activate randomly.
