Casio G-Shock GW300CA-1V Wrist Watch
Battery issues,......
shared by 8 users
posted by plantman1 on Jan 05, 2008
My gshock is blank right now. I put it outside to see if it will charge. This issues just started happening 2 days ago.
Thanks
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Posted by Halo572 on Jul 14, 2008
I have had exactly the same problem, less than 2 years old, stays on medium and drains very quickly. Having had a look at the manual posted by Robotek I left it in full sunlight for a couple of days and it is now on full for the first time in 6 months. It is a limitation of the cells so I have just accepted it, it's still a great watch.
So - try it in FULL AND DIRECT sunlight for a couple of days and if this doesn't work maybe it does need a new battery. Not sure how this will work in the winter, but sitting on a table near a window didn't charge before it either.
Posted by 4mer82d on Mar 18, 2008
My G-Shock is doing the same thing, it won't stay charged for more than a day, and it's only a couple years old. Does anyone know how long it should take to fully charge?
Posted by Guest on Feb 16, 2008
My GW-300 also started losing the ability to fully recharge recently. I ordered a new rechargable battery and after replacement it works fine again.
Posted by Guest on Jan 24, 2008
I have the same watch and mine just started flashing charge also. I am going to replace the battery and see if that doesn't fix it. I think the fact that it is winter and the watch hasn't been exposed to much sunlight has a lot to do with it.
Posted by measley on Jan 16, 2008
same problem. Goes to Medium, backlight doesn't work, watch less than 2 years old
Best Solution
posted on Feb 14, 2008
FixYa! (100)
robotek
Rank:Guru Guru
Rating: 90%, 684 votes
Hey all, here is a site that has good instructions on how to change the battery in your G-Shock watch. Sounds like you are suffering a low batt problem.
http://forums.watchuseek.com/showthread.php?t=20217
If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
regards
Graeme
Comment posted on Feb 14, 2008
But then the instructions I have given may not spply to you if you have a "solar"powered watch where a special type of rechargeable battery is used. Even rechargeable batteries dont last for ever and have a finite number of charge/discharge cycles. If your watch does not appear to be charging, Casio have explicit instructions on how to bets generate a charge from the sun. If attempts to charge fail... it is probable that your "rechargeable" battery is failing and will need to be taken to a Casio agent for replacement.
oh, and here is a link to a user manual for this series
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2931.pdf
hope it helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Battery issues,......:
I don't want to Accept this solution
Solution #2
posted on Sep 08, 2008
Not Rated (0)
tomasion
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thank You!
Solution #3
posted on Apr 13, 2008
Not Rated (0)
edgon333
Rating: 0%, 0 votes
Replace the rechargeable ctl1616 which costs 20 bucks or more with a cr1616 about 1 buck, works fine and I never have to put up with the dreaded blank screen. Before this fix I replaced the rechargeable ctl1616 twice, each one died after about two years. Now I just use the lithium cr1616, never a blank screen again.
Thank You!
Can you Help with these Watches problems?
I am replacing the bat in the casio 3319-AQ-160 and there...
How do I change time on Casio g shock gw300?
can anyone help me figure out how to change the time and...
i need the instructions.
Hi, I saw your comment about the G-shocks actually not...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 07, 2008
A month or two ago my gw-300 stopped charging. At first if I left it in direct sunlight for a few hours it would come back on, but after a few minutes it would start flashing "charge" (or something like that ... It doesn't show anything anymore so I can't check) I happened upon another gw-300 owner and he said that his battery died as well. He said that he called Casio and that they replaced it no problem. I'm going to try the same thing.
Comment by jumbehr, posted on Jan 06, 2008
I'm having the exact same problem, a g-shock bought less than 2 years ago has been reading med charge for a few months (and the backlight quite working) but on friday 1/4/08 i woke up and it was blank and "charging." Its been that way since
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
