Question about Philips 9P5034C 50" Rear Projection Television
Magnavox Projection Model # 9P5034 C101
I posted a question earlier and troylove11 replyed.....He told me the convergance amps need replaced for my Magnavox Projection Model # 9P5034 C101....My other question is...... I work in the electricial field and can make needed repairs, just need some guidence. I have minimal experience on tv repair. Are the amps located on the digital convergence board ? Will I have to discharge any high voltage from amps or convergence board before replacement or will they auto discharge ? Where do I purchase the amps ? Any other info on replacing these will be greatly appreciated. ! THANKS FOR ALL THE HELP !
    Genius:
  • 1,153 Answers
Yes you will need to discharge any electrical equipment before working. One way of doing this is keep equ. unplugged for sometime or after unplug short hot to ground which will most times cause a spark. You can go to vancebaldwin.com or andrewelectronics.com or any online parts store and get the part number off old IC, yes these are on the convergence module. They are big STK's, also there are resistors that will need to be changed and maybe pico fuses.
Posted on Jan 05, 2008
SOURCE:
Philips 46pp930217f convergence problem
Goto www.TvRepairKits.com and get a complete kit with instructions. Of get them from parts suppliers -but watch out for clone chips - only get OEM originals - avoid Ebay
Mar 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
7P5441 C101 54in color is wrong
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence issues...green glow around objects on the screen
a green glow sounds more like a coolant issue more than convergence. Is your TV a phillips or magnavox by any chance? Please reply to this same post and let me know your model number.
Jul 28, 2008 | Televison & Video
Magnavox rear projection
If the red converge will not line up, then there the convergence chips are actually bad - the repair will cost around $700 if you go through a Magnavox authorized service center. I would look at posts by Slinteriors in the Philips or Magnavox rear projection sections - he has some ideas on generic chips that might be had for cheaper.
Jul 06, 2008 | Toshiba 55H70 55" Rear Projection...
PHILLIPS MAGNAVOX 60 BIG SCREEN 9P6040C101
can you post a picture of your screen or send it to my email [email protected] as it sounds like its just the convergence Ics and the 6.8 ohm resistors, but a pic would help me do a accurate diagfnosis.
Jun 28, 2008 | Philips 55PP9363 55" Rear Projection...
Sometimes it turns on, sometimes it doesn't,9P5034 C101 PHILIPS
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 18, 2008 | Philips 9P5034C 50" Rear Projection...
Phillips Magnavox 9P6031 C101...
Find a universal remote with a menu and four arrow keys, b/c Philips is out of the original. Or, you could call Philips and find the number for one of their authorized centers - a TV repair man may have a stockpile of them from cust's who abandon their TVs.
Feb 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
no this is what you need...
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
or send it in for repair here
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Projection Convergence
You may have had another problem if the screen was wavey. This is typicaly caused by the opto chip. Check www.magnavoxhelp.com for more details.
Jan 12, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
320 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
