Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
Mathematical Calculation Good Day, My mathematical problem is as follows: Say I need to calculate the amount to invest on 6 companies to get a profit of say $300-00 plus the amount I invested on all 6 companies. As per the table pasted below, I need a formula to calculate the invest amount for each company so that I will always have a profit of $300-00. Hint: Only 1 company gives a return and the rest you loose. Hint 2: I tried to calculate the Lowest Common multiple to resolve this but it does not always work. Please assist. Company Return RateInvestment AmountTarget Profit $ A5.4?300 B8.9?300 C11.1?300 D6.7?300 E4.3?300 F7.1?300 Jowi South Africa nkwejm@telkomsa.net
    Problem Solver:
  • 5 Answers
Following formula we can use.
S=P(1+RT)
WHERE S =INVEST AMOUNT+PROFIT
P=INVEST AMOUNT
R= RATE OF RETURN
T=TIME IN YEARS
EX : (300+x) = x(1+(5.4/100)*1)
(300+x)*100 = 105.4x
x=30000/5.4
x=5555. 4
Posted on Feb 19, 2008
What is the method of calculating interest rate for fixed deposit?
Fixed deposit calculations can be done by both manual and automatic methods.Now let us figure out the fd calculation in both ways:
1.) Manual Calculation Technique: It is the conventional process to know your Fixed deposit interest calculation. The formula for manual fd calculation is used as below:
Where,A = Final Amount
P = Principal Amount (initial investment)
r = Annual Nominal Interest Rate (as a decimal, not in percentage)
n = Number of times the interest is compounded per year
t = Number of years
2.) Online Calculator Technique: Nowadays online FD calculator is very amazing technique and it is a very useful online tool that helps you to easily calculate your Fixed deposit return. Online FD calculators uses simple technique in which you need to put your amount, tenure, interest rate and can get accurate results instantly. You can easily calculate and compare the interest receivable by changing the deposit amount.
Mar 18, 2018 | Finance
If a house is 1400 square ft. How many linear ft does that convert to?
if the area is 1400 square feet the lineal is 149.6 ft outside edge from a square 37.4 feet on a side, to 2802 ft outside edge from a rectangle 1400 by 1 foot wide. After that the calculation is the number calculated by the formula below multiplied by two plus the length of the ends. The narrower the strip, of course, the longer the linear distance until you have an infinite length line of infinitesimal width and you have created a perfect mathematical construct of two dimensions
The calculation for determining the lineal distance that the internal area can be converted to is:
L=1400/n where n=the width of the strip required in feet
eg in 1foot wide strips n=1 so L=1400, in 6" wide strips N= 0.5 so L=2800.
Dec 14, 2017 | Linear Office Equipment & Supplies
How to you make the impedance calculation?
Impedance is the opposition of a circuit to alternating current. It's measured in ohms. To calculate impedance, you must know the value of all resistors and the impedance of all inductors and capacitors, which offer varying amounts of opposition to the current depending on how the current is changing. You can calculate impedance using a simple mathematical formula.
  1. Impedance Z = R or XLor XC(if only one is present)
  2. Impedance in series only Z = ?(R2 + X2) (if both R and one type of X are present)
  3. Impedance in series only Z = ?(R2 + ('XL - XC')2) (if R, XL, and XC are all present)
  4. Impedance in any circuit = R + jX (j is the imaginary number ?(-1))
  5. Resistance R = I / ?V
  6. Inductive reactance XL = 2?ƒL = ?L
  7. Capacative reactance XC = 1 / 2?ƒC = 1 / ?C
Sep 09, 2016 | Office Equipment & Supplies
How do I change above from Celsius to Fahrenheit degrees
Use this practical online calculator. You can find there also the mathematical calculation
http://www.rapidtables.com/convert/temperature/celsius-to-fahrenheit.htm
Jul 09, 2015 | Microwave Ovens
How to do matrix problems in fx991ms
The following was written for the Casio FX-991 ES. If matrix calculations are available on your calculator you will perform them as described below. ( I have no time to verify that the FX-991ms can perform matrix calculations).
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matricies, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match.
Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular umbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrice by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Nov 07, 2012 | Casio FX991MS Scientific Calculator
How to multiply the matrices using fx-991ms calculator
Nov 06, 2012 | Casio FX991MS Scientific Calculator
Convert metric weight to pounds
1 Kilogram (Kg) = 2.20462 Pounds (Lbs)
1 Pound = 0.453592 Kilograms
See the following links for Online Conversion Calculators:
http://www.metric-conversions.org/weight/kilograms-to-pounds.htm
http://www.metric-conversions.org/weight/pounds-to-kilograms.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Apr 22, 2011 | Office Equipment & Supplies
WhAT IS AN Ma error
It is an abbreviation for mathematical (calculation ) error:
You did not actually ask about how to cure the problem, but here it is.
1.Calculation exceeds calculation range.
2.Calculation outside the input range of a function
3. Illogical operation (division by 0)
4. Poor precision is Sigma calculations (stats)
For all the above check input values.
5. Poor precision in differential calculation results (derivatives:decrease the delta, the step)
6. Poor precision in integral calculation results ( integrals: Change the tolerance tol)
7.Cannot find results in equation calculations (Check coefficients of equations
Take your pick of the above:Only you know what you were doing before the error condition arose.
Hope it helps satisfy your curiosity.
Oct 19, 2009 | Casio CFX-9850G Plus Calculator
Bank process in daily interest calculation
I want how i can calculate daily profit /loss calculation on investment
Sep 07, 2009 | Microsoft Step by Step Visual Basic 6.0...
How we can get age while entering date of birth in text box in C#.NET 2003
Look up Gauss' Algorithm for finding number of days between
two dates. Then divide by 365.25. Straightforward mathematical
calculation.
Mar 07, 2009 | Microsoft Computers & Internet
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
329 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
