Nintendo Wii Console
Problem for Nintendo Wii Console
Nintendo wii
By rambo18 on Jan 05, 2008
error code 51330
Same Problem
May 15, 2009
-   i have the same problem man.. -   Guest
Jan 16, 2009
-   can find the thomson tg585v7 will not connect please help andrew-   tooly8
Apr 06, 2008
-   unable to connect to the internet - error code 51330-   Guest
Best Solution
posted on Mar 08, 2008
Helpful)
larkin71
Rank: Wiz
Rating: 88%, 67 votes
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right after started to fall in place perfectly, just try what password type will work for you...my wii started connecting to my router and never had the same error code ever since.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 22, 2009
Very Helpful)
hamsandwich
Rank: Guide
Rating: 100%, 2 votes
I got this of the nintendo website. It's complicated but it works for me!
Error Code: 051330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
    If you are still receiving this error code, please click here for assistance.
Was this helpful?
Yes
No
Solution #3
posted on Nov 28, 2008
Very Helpful)
Arceusman
Rank: Master
Rating: 83%, 12 votes
Go here: support.nintendo.com and enter the error code on the box and it should tell you the solution.
Was this helpful?
Yes
No
Solution #4
posted on Apr 16, 2009
Not Rated)
Danster5oo
Rank: Guru
Rating: 86%, 53 votes
This error code means that the signal is to far. Find a closer position to the router or set it to a different setting.
Was this helpful?
Yes
No
Popular Solutions for Nintendo Wii Console
Questions and Unsolved Problems for Nintendo Wii Console
Do you recommend Nintendo Wii Console?
Answer
Answer
I have the game call of duty : world at war, when i try to play it online, it tell me that the... (More)
Answer
Sudently none of my wii remote seems to work.When i press the a button, lights flashes but ther,se... (More)
Answer
my wii wont turn on checked connections all seem fine
Answer
I cant turn my wii on at all, checked connections all plugged in but no power
Answer
I just bought my wii two weeks ago, all was going well till two days ago, while playing a game it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
