Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Problem for Sears Craftsman LiftMaster Chamberlain Garage Door Opener...
My 1/2 hp craftsman garage opener won't go down
By blacy on Nov 06, 2009
My 1/2 hp craftsman garage opener was working great up until last night. the door started to go down, got about 2 feet and went back up. I checked the unit and found that the mounting screws on one side had loosened to the point that the motor unit would move forwards and backwards just enough to cause the problem. so I tightend everything back up knowing that this was the issue and it did work twice and upon the 3rd try it stopped and went back up again. is it possible that it is to tight and binding the wheel? Nothing should have changed much from before and I know the unit is in good working condition. Do I need to disconect the chain and reattach it? thanks in advance.
Best Solution
posted on Nov 06, 2009
Very Helpful)
avmann
Rank: Guru
Rating: 92%, 27 votes
It sounds like it is out of alignment. The motor does detect excess pressure incase something or someone is underneath and the light sensor is not detecting anything. The pressure on the motor does change from when the door is all the way up to when it has the full weight of the door on the chain before it touches down. The spring offsets most of the weight of the door, but it still takes weight. Maybe when the motor is taking more of the weight, it is still shifting in a way to throw off the alignment. Also, you could disconnect the door from the chain, try manually moving the door and see how much weight the motor is taking at what points. Good luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" The mis-alignment sounds very possible, I will try running it manually and see how it goes. thanks for the quick response. " - blacy
Popular Solutions for Sears Craftsman LiftMaster
Questions and Unsolved Problems for Sears Craftsman LiftMaster
Do you recommend Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+?
Answer
Answer
I just changed out the gear and sproket assembly with no problem. The nylon gear was badly worn.... (More)
Answer
Replaced Gear and Sprocket on my liftmaster and now the lights and motor do not turn on. Is there a... (More)
Answer
How do I get my light to stay on after my garage door has openned?
Answer
my 10hp 5600w generator only runs for approx 20 mins then stalls. fires back up on first... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Security Systems and Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
