Question about LG VX8300 Cellular Phone
Vx8300 stuck in car kit
My vx8300 is stuck in car kit
  • 1 more comment
  • Anonymous Jun 02, 2008
    spilled tequilla on phone it is stuck in car kit,i can text,there is no voice when calling or recieveing
  • judia54 Jul 14, 2008
    Verizon LG, stuck in car kit mode, there are no sounds. I can call out but no one can here me, I can recieve calls but I cannot hear the party.
  • vturley_turl May 05, 2009
    i have a vx8300 verizon phone my phone was dropped in water and now it's stuck in car kit mode what can i do to fix this problem?
I just ran into this problem myself (besides that fucked up white main screen i have). So after reading all these other solutions i played with the thing and found that its one of the right-most pins in the charging port. Probabily a pin touching the metal housing or another pin completes the same electrical circuit used to determine if a car kit is hooked in. I figured this one by shoving a knife through the opening to clear out any debris and every-swipe made the "car kit" banner dissappear. so check for pins touching something it shouldn't. ( i said F-it and ripped that pin out!)
Hope this helps more
Posted on Sep 28, 2008
Go with Stonerhippie's solution!  I tried the tin foil thing, the resetting, the alcohol, didn't work.  Finally I looked inside the charging port and saw that a couple of the rightmost pins were crushed down a little, so I took a pair of tweezers and carefully pushed them around a little, away from the side of the port, and the Car Kit thing disappeared immediately.  Thanks!
Posted on Apr 24, 2009
  • oasis72gds Apr 24, 2009
    sdf
  • StonerHippie Oct 28, 2015
    Your welcome. Obviously its not always the issue, as corrosion can do the same thing, but like I said, (unless you have a car kit):
    When in doubt, rip it out!
  • 21 Answers
OK here is an easy fix for that... you either need 99-100% rubbing alcohol or an item called tech spray which is usually sold at most hardware stores. get an old toothbrush and get the alcohol on the toothbrush and use that to clean the charging port. If that doesnt help then take the charger and plug it in the phone and wiggle it around ever so lightly. That should take care of it.
Posted on Sep 27, 2008
I sprayed industrial electrical circuit cleaner into the charging port (nothing to loose) followed by compressed air form my air compressor and it fixed the problem. Verizon could do the same thing for their customers. But the $$$$ get in the way.
Posted on Sep 22, 2008
None of the proposed fixes worked, so I took two aspirin and watched "Cedar Rapids" twice; first time laughed, second time cried. Sweet little movie.
Next day I put phone, with charging port ******* directly upward, in sun for 4 hours to bake. Then I worshipped sun when its drying effects got rid of dreaded Car Kit.
Posted on Aug 14, 2011
  • spazapple Aug 14, 2011
    The word "***" got ***** out by the Thought Police on FixYa. Great work.
I tried stonerhippe's solution of playing with the right most pins with a paper clip. Car Kit flickered, but kept coming back. Then I read nos7116's solution. I didn't have rubbing alcohol, but I had Purell. I shoved a whole mess of Purell into the charger end (good idea to pull the other end out of the wall first). Then I shoved that Purell dripping end into the phone charging port and wiggled away. Work in 2 secs!!
Posted on Jun 30, 2011
    Well mine obviously was either the pins touching, or corrosion as they both can essentially function the same way as a short... but the point of my fix was really to tell people where exactly the problem is located, so they can find out why it's messed up.
    and unless they need that pin, as for using a car kit, they should just get rid of it- cuz its just going to cause problems since those pins are so tiny, the slightest movement can cause this.
    But other than my fix, the best advice I can give to anybody is find out for yourself... play around, and figure it out through trial and error, than choose the preferred course of action from there based on your observations.
After mine got wet in a water balloon massacre, I cleaned the charger area with tissue with rubbing alcohol on it and worked for my 8300.
Posted on Aug 11, 2008
Verizon used to fix this problem before they found it was more profitable to make everyone buy new phones.
The same daughter slobbering problem happenned with me and I took my phone into verizon and they fixed it(couple years ago)-The problem is in the spot where you attach the charger-there is corrosion from the moisture and that corrosion is connecting the little wires that go into the charger-which is what the car kit accessories would do....
You need to remove the corrosion from in between the wires-at the verizon store-the tech guy told me he used rubbing alcohol and a q-tip to clean that area..
Posted on Feb 29, 2008
Spray compressed air in the charger area! it worked on mine
Posted on Jan 28, 2008
Your phone probably got damaged where you stick the charger, it may have got wet.
My daughter slobered on my phone in that spot and kick it into car kit mode. Verizon said that it was ruined and had to replace it
Posted on Jan 09, 2008
3 Suggested Answers
SOURCE: my lg vx8300 phone
Most likely exposed to water...even at low levels. I put mine in a bowl of dry rice. Worked great to dry it out. Worked in one day.
Posted on Aug 18, 2008
  • 80 Answers
SOURCE: Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Posted on Jul 11, 2010
Stuck on car kit mode
I tried just taking out the battery, turning it off and on, and screwing with the settings. I took the battery out and a ran a mental fingernail file across the top and bottom of the pins where normally charge the phone from. I put the battery back in and it was out of car kit mode. It is working fine now! You can try this too.
Feb 15, 2011 | LG VX8300 Cellular Phone
Jun 23, 2010 | LG VX8300 Cellular Phone
Phone says
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. There is no specific setting to turn on or off 'car kit' mode
Mar 25, 2010 | LG VX8300 Cellular Phone
LG VX8300 stuck in 'roaming mode'
Try taking the battery out and resetting the phone.
Aug 27, 2009 | LG VX8300 Cellular Phone
I cant get my LG VX8300 verison wireless cell phone off of car kit.
I had the same problem. I used a hair dryer to dry out the port of the charger on the phone. Then I put the charger back in overnight, and in the morning the Car Kit was off of it. I was surprised it was so simple.
Feb 18, 2009 | LG VX8300 Cellular Phone
Car kit
My cellphone is stuck in car kit mode and i cannot hear anyone calling me but i can text people. How do i get this feature off!
Sep 05, 2008 | LG VX8300 Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
My phone is stuck on car kit and no matter what i try nothing from the the responses on here work. can you help me?
Have you have gotten the phone wet in some way or the other? Try blowing out the data port on the bottom of the phone with some kind of compressed air.
Jun 05, 2008 | LG VX8300 Cellular Phone
How do I pair an LG VX8300 cell phone w/ Volvo bluetooth car kit
Here are the full instructions from LG.
Dec 20, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
1,944 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
