Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washing Machine not spinning
I have a Hotpoint Aquarius WD640 Front Loading washing/dryer and it goes through its cycle however does spin on full power. The motor does not have any carbon brushes which i would normally thought would have been the problem. Also the dryer is not drying clothes they are just as wet. Any suggestions
  • Basset Man Oct 19, 2008
    I have a similar problem, I have a WD64. It completes all elements of the cycle, but will not spin during the spin cycle. It turns during washing and rinse. I have had the sump and filter apart to check this was not blocked, because this has caused problems in the past. I also checked the drain pump and associated hoses, all of which are clear and the motor runs fine. Running the machine empty seems to suggest that the water is filling and draining correctly. Just no spin during spin cycle??
    Any help would be gratefully received.
    Many Thanks
    Nick
    Master:
  • 619 Answers
Bring your sample to appliances store let them chech if their available.
Check the heat sensor detach one line test the continuity both terminal if open replace it.
Posted on Jan 05, 2008
6ya staff
SOURCE:
After a wash the water is not emptying out of the we64 aquariouse extra, hotpoint. how do i fix this? thank you
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Bbbbb
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 28, 2010 | Hotpoint Aquarius WD640 Front Load...
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine wont go into spin cycle
The pump fiter is probably blocked.
Remove lower rear panel of washer.
Locate, and remove large black hose on bottom of tub.
Remove plastic filter inside, and clean.
Refit filter and hose.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint erorr f01
sounds like a faulty water valve regards jason
Jun 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
160 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
