There are two types of pumps; direct drive and belt drive. The direct drive is mounted directly to the motor, the belt drive is mounted to the chassis. The direct drive style can be opened for complete inspection while belt drive models may or may not be designed to be opened. You can however, still remove the hoses and inspect the ports for a blockage. Inspecting the pump is fairly easy to do, but you will most likely have to open the washer's cabinet.
Typically one of three problems occur with the pump. The first is a blockage in the pump, often from small items like a sock. The second possibility is that the impeller blades become broken or worn down and cannot move water efficiently. Finally, in belt drive models, if the belt is loose or broken it does not turn the pump.
Locate the pump, it will have two, three or four hoses. Label each hose and where it connects. The hoses should each have a wire clamp or a hose clamp with a screw. Pinch the wire tabs together with pliers and wiggle the clamp farther up the hose. Screw style hose clamps are simply loosened by turning the screw, then slide the clamp up the hose. Now remove the hose from the port.
Direct drive pumps have metal clips that hold the cover plate unto the pump assembly. Use a screwdriver to pry up the clips and remove the cover. Pull off the pump's impeller unit and inspect for damage.
Belt drive pumps vary and may or may not be designed to open for repair. Examine the pump to determine whether it can be opened. If it cannot be opened the look into the ports for any blockage.
DRAIN FILTER
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line. If there are no blockages,and the lines are clear, the pump will be the culprit.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Affinity ATF7000E
After 10-15 min after starting the wash when its in warm or hot - I get that beeping that states E10...
(More)
After 10-15 min after starting the wash when its in warm or hot - I get that beeping that states E10 The washer works fine when its run on all cold.
my washer does not want to spin out...it will wash but when i get to spin it stops...it also has a...
(More)
my washer does not want to spin out...it will wash but when i get to spin it stops...it also has a error code of E23 something with the interface board or loose wire . I check and no loose wire
