Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Di-624 stopped working
My wireless router worked fine till yesterday. All green lights are on but cannot connect to the internet. I can connect if I switch over to just my DSL connection. Called tech support 3 times, they had me download firmware version and reset by dlink. Nothing seems to work. One tech told me that my router was no longer any good.
Any suggestions?
    Novelist:
  • 101 Answers
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Posted on Jan 05, 2008
I have internet connection through the modem but the DI-624 router will not allow an internet connection.
If you had a USB or Wireless card and your router have slots to plug them on, it you can set your router to work as an "Access Point"
Oct 04, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
D Link DI 624 stopped talking to computers
Just a matter of accessing router software and re- typing U/N and P/W
Dec 23, 2009 | D-Link Computers & Internet
Connecting d-link di-624 router with ipod touch
I configured my D-Link router, choosing an SSID, and a password for all wireless connections.
I configured my iPod Touch to connect to that SSID, and specified the password, and it works fine.
So, it works for me, and it can work for you.
Apr 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lights are solid green: WAN, local network 1,2,3,4
If that is status of the lights on your router there's a big possibility that its already bad and needs a replacement, but you can first try to reset it and check if that will correct the problem
, To reset the router just press and hold the reset button for 30 seconds while the power is ON then after that check if the lights are back to normal if still the same light router is already bad...
Dec 01, 2008 | D-Link AirPlus Xtreme Super-G DI-624...
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link DI-624 won't work!
hi thanatos
try resetting the router back to default settings by holding in the reset button for 30 seconds this is found on the back of the router you will need a small pointed pencil or paperclip to do this
Feb 08, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-link DI-624 wireless router connectivity problems (DNS suffix)
Might I suggest that you reset the router to its default configuration by pressing and holding the reset button until it reboots. This way you will be dealing with the default configuration. Then try to use it. Remember the default login ID is admin and the password is Password or admin. Lets hope this helps
Sep 04, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
133 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
