Question about Panasonic DVD-CP72 Multi-disc DVD Player
Panasonic dvd-cp72 no matter what type of disc you put in it say,(this type of disc cannot be played please insert a different disc
    Scholar:
    New Friend:
  • 70 Answers
Asptroy,
hi mate, just want to know first if what region indicate at the back of your DVD player? the reason why i ask you, is because most of branded DVD have their own region for ex. for asian countries they are tagged as region 3 and Australia region 4 ...... most probably your player is not configured to play multi region disc if it can't play any disc. The only way to check if your player have a problem is to check the region of your player and if you can barrow or buy a dvd disc having the same region. or simply check for DVD disc which indicates that it is a all region compatible. Actually this is only info that i can share, but if your only near in my place i can help you change your dvd player to become a multi disc reader simply by clicking some activation keys using the special remote control specially design to configure and modify region setting of panasonic players.
cheers,
markiez23
Posted on Jan 15, 2009
How to make region free dvd
Usually a region 1 DVD player will not be able to be a multi region because it needs to be able to convert between pal and NTSC to play on your NTSC TV. Unless the player is a European model then it would be possible!
Oct 01, 2015 | Panasonic DVD-CP72 5 Disc DVD/CD Changer
Dvd player gives message "this
Tries many more DVD discs tries to check it out as the disc u insert in the DVD player tray have difference region format disc that why u getting that answer.
Jun 05, 2011 | Panasonic PV-DM2792 Triple Play 27 in....
Problem with the dve player
You may have to check the options for the player. Some DVD players cannot play formats other than regular DVDs. You can check the options to see if it can be put in a different mode from the normal one, such as progressive scan, which can help it to read DVDs better in some ways. You can also set it up to accept more types than just DVDs, but also DVD-Rs and VCDs. I cannot tell you, without fiddling around with it, whether you will need to take it in to a shop, but that is an option. Once you see about adjusting some of the settings, see if it won't play a DVD.
Oct 23, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Jul 23, 2009 | Panasonic PV-20DF64 20 in. TV/DVD Combo
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
DVD doesn't play any disk anymore. Displays a message: this can't of disc can't be played ... I tried several different types of disks.
Same here! It would say something along the lines of "this type of disc cannot be played. please insert a different disc." it's the appropriate dvd region, i've tried all types of dvds, and it still won't work. the vhs and cd still works, it's just the dvd player that won't.
Mar 30, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Dvd player
it could be that your lens needs to be cleaned
Aug 07, 2007 | Panasonic PV-27DF64 27 in. TV/DVD Combo
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
Jun 29, 2007 | Panasonic PVD4744 DVD Player/VCR
Panasonic DVD-CP72 Multi-disc DVD Player Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
