JVC TM-2703SU 27
Jvc av-29ts2ek
posted by bex8 on Jan 05, 2008
the top inch of the picture was distorted, & now just a white horizontal line in the middle of the screen with the sound then after 5-10 seconds it swichtes itself off
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 05, 2008
Helpful (85)
wyoed1
Rank:Guru Guru
Rating: 86%, 136 votes
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on jvc av-29ts2ek:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
JVC TM-2703SU 27" TV
i turn on set by manual on button on tv as remote wont...
the color onthetv to dark ,and the cc words jumbled, could...
When you push the start button it clicks but nothing turns...
One day the tv just turned off randomly and wouldn't turn...
timer light blinking and no picture except horizontal...
Loading problems.
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
