Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Was this helpful?
Yes
No
Popular Solutions for Brother MFC-8460N All-In-One
Put paper in. Loud clicking noise like the gear in the machine is jumping as it is trying to lift...
(More)
Put paper in. Loud clicking noise like the gear in the machine is jumping as it is trying to lift the paper in the tray. If I only put in a couple of sheets it will work. It is as if the gears are to far apart from each other.
can you turn off the LCD on the 3 function keys , we have gone through the menu completely and have...
(More)
can you turn off the LCD on the 3 function keys , we have gone through the menu completely and have found nothing. Have found that at night the room is lite up from brightness from the function key that is on.
