Question about LaCie (300728U) 250 GB Hard Drive
Problems with files invisible
Hi i have a BIG problem with my disk... i got a fully loaded Lacie 250GB but when i open it every sige file is gone... it's taking upp the space and it is stored and not deleted but it simply does not exist for windows... i had this problem before so now i got a 42mb drive instead of a 250GB.. witch no files on it... and i REALY need those files.
Download virtaul lab it will help get your info back
Posted on Apr 05, 2008
  • 1,006 Answers
Download THIS program and copy it to cd.Bot pc from cd and look for one program araonic program.With it you can repair hdd BUT YOU CANT RECOVER NOTHING!
Posted on Jan 05, 2008
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Regalo di Natale LACIE S+ARCK 500 GB sprovvisto di CD di intallazione
this drive does not come with an installation CD. All the files and softwares provided will be installed after running the LaCie setup assistant. If you formatted the drive or if the setup assistant failed, contact LaCie to get the files you are entitled to.
Regards,
Jan 02, 2011 | LaCie Big Disk 500 GB Hard Drive
I cannot seem to delete the files from my Lacie hard drive. The message says that I have no authorization to the files.
use a boo table dos disk and use dos to delete these files, if you need more info on how to do , use a windows commander, or Norton commander 40
Dec 19, 2010 | LaCie Big Disk 500 GB Hard Drive
LaCie BIG HD suddenly invisible to my Mac
from the description either th drive or the 1394 logic board has failed. Try having the technicians at you local PC shop swap the actual hard drive from the Lacie enclosure into a new enclosure and test it. If it works, buy the enclosure and you're back in business, if it oesn't and you need the data on the drive comment back with your Country, State & City and I'll refer you to a good Data recovery specialist in your region.
Hop this helps FixYa,
Chris
Jun 27, 2009 | LaCie Big Disk Extreme with Triple...
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Lacie 250GB changes date when copied
Unfortunately, when you copy a file, you are technically creating a new file hence it would assign the current day's date as the new date.
Jan 14, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Disk full message
Do a bit of arithmetic - go to each folder right click, then click on properties and take note of the size of each folder. What does that add up to? Any unusually large files? Has it been partitioned at all?
May 14, 2007 | LaCie (300728U) 250 GB Hard Drive
Lacie 250GB external HD (Error Code - 1309),
For systems prior to OS X; error -1309 fileBoundsErr: file's EOF offset mark or size is too big If your disk is formated as HFS rather than HFS+, you can get this error. For OS X; Error 1309 is a file bounds error. In other words there is some discrepancy with the file's size or end-of-file marker, or some variation on this. This sounds like a read error not a write one i.e the problem lies with the original file. Now, you may ask, "How do I make it HFS+?"... You would have to reformat the drive to change the formatting to HFS+ (Extended). Backup anything you can't replace on that disk, then use Disk Utility in your Utility folder to reformat the disk. Use Extended formating option.
Mar 27, 2007 | LaCie d2 Extreme 250GB External with...
LaCie (300728U) 250 GB Hard Drive Logo
98 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
