Hi, This problem actually related to misalignment of mechanical tape path of cassette loading assembly, please follow the procedure given below:
"Remove the battery or power cable, connect, and perform operations from the beginning."
If problem persists then you have to contact any expert nearby for the mechanical adjustment of tape loading path assembly because its a bit tech job and can perform by an expert, Let me know if you have any experience along with proper tools then i can describe how to fix it. Thanks for using fixya.
i have a sony handycam ccd-trv57 it has a problem when im charging or recording with shuting off and...
(More)
I HAVE A SONY HANDYCAM CCD-TRV57 IT HAS A PROBLEM WHEN IM CHARGING OR RECORDING WITH SHUTING OFF AND TURNING BACK ON DONT KNOW WHAT THE PROBLEM IS ANY HELP WILL HELP ME ALOT THANKS TIM HYATT
How do you get the Date/Time battery out? When you turn the Camcorder on it starts flashing...
(More)
How do you get the Date/Time battery out? When you turn the Camcorder on it starts flashing "for Ion Lithium battery only" and then it shuts off. It also flashs one of the following two codes; C:31:42 and C:31:40. I had the manual and battery in a plastic bag that my mother-in-law thought was empty---she threw it away. I've purchased a replacement Ion Lithium battery but that didn't help either. I love this camera more than the lighter weight mini DVD Sony camcorder that I purchased to use. HELP!!!!
Sony Handycam CCD-TR83 NTSC won't play audio RCA's or headphones? New problem just develpoed....
(More)
Sony Handycam CCD-TR83 NTSC won't play audio RCA's or headphones? New problem just develpoed. Trouble shooting different RCA wires and televisions concluded possible internal sound card issue??? Can I salvage audio through the RFU plug that is stationed next to the camera's RCA plugs and if so what adapter or aftermarket wire do I need and could Radio Shack carry this? I'm desparate to salvage recent video and audio from the tapes I have recorded which incidently played the audio fine previously. The audio settings have been switched back and fourth between the 3 different audio settings as well with no change. Any suguestions would be greatly appreciated. Thanks, Todd
The door will close when no tape is present but when I put a tape in the motor just barely moves and...
(More)
The door will close when no tape is present but when I put a tape in the motor just barely moves and stops. When I push eject with no tape in and the holder rises one of the tape rotors keeps spinning for a while then shuts off.
When tape is inserted and door is closed the motor spins for about 10 - 15 sec then door opens. Will not retract into the camera. If no tape inserted the door closes and retracts as it always has. No moisture sensor or any other warning light other than a slow yellow blinking "no tape " light. I tried removing the battery and using direct power with no sucess.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
