What key do u press at startup of computer to reformat windows using recovery partition phillips mt6000
I canot play my media player, and it saying that i have to open url or http but still its not working, pls help me about this, and evrytime im serching something it just stop automatically, thank you
First you need the winxp or the vista installer then the first key upon open up the power of your keyboard press delete for about 5 to 10 seconds to open up your the bios setting.then, configure your bios setting by setting the cd rom as your 1st boot device insert your winxp or vista cd then save and exit the computer will then automatically restart then follow the instructions on screen
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
