Question about LG 42PC1DA 42 in. Plasma HDTV
Red dots on a black background
I brought this tv over a year ago and just recently i've been seeing red dots on the screen where it should be black, can you help
  • 3 more comments
  • Pants13 Jan 05, 2008
    Sorry to sound like a numpty but how would i go about doing that
  • Pants13 Jan 10, 2008
    how do i reduce the Vs value once i have monitered it
  • Anonymous Jan 11, 2009
    i have little red dots flickering all over the screen in areas that are dark but its only when im playing my xbox is this a problem with the t.v or the xbox my t.v is a 32 inch lcd hd ready
  • mean2bu Mar 22, 2009
    In dark areas the screen will ghost a previous bright picture with red dots
  • adenorv Apr 30, 2009
    zjut, Can you use any sort of mains filter to achieve the same result without taking the back off??
  • 106 Answers
Try to adjust the Vs down about 5-10V.
Posted on Jan 05, 2008
  • Anonymous Jan 06, 2008
    Open the back cover and you'll see the Vs specification printed on the back of PDP panel. Vs is from the Power Supply board. Using a multimeter to monitor the Vs and reduce its value 5-10V below its spec. First try this simple way. If it does not work, you may need to replace the YSUS board of your tv.
6ya staff
SOURCE:
Screen is displaying Red background color with glittery pixels effect around the figures
Please change the T-CON board, if it did not fix the problem, you may have a defective LCD Panel.
Apr 24, 2017 | Samsung LN52A650A LCD TV
Pixelation
The problem is more or less with the LCD screen itself. The manufatcurer covers dead or burnt pixels.I would suggest contact Vizio Support on the following number
Technical Support
Toll-Free: 877.698.4946
Thanks
proton
Aug 09, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Dec 31, 2008 | LG 42PC3D 42 in. Plasma Television
White dots on screen
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
Plasma TV Fault
What is the make and model #?
Jan 14, 2008 | RCA L46WD22 Television
Blue out of focus; casting blue "glow"
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
LG 42PC1DA 42 in. Plasma HDTV Logo
917 people viewed this question
Ekse
RONALD CARTER JR
