PC Cases
Generic problem for all PC Cases
NEW ULTA V Series 350w power supply .
posted by lonewolfone on Jan 05, 2008
I just got a new tower ULTRA DEFENDER with an ATX ULTA V series 350w power supply. The tower comes with an 120mm case fan were does this plug in? To big for mob. doe's this plug into power supply?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 19, 2008
Not Rated (0)
campus
Rank:Guru Guru
Rating: 89%, 45 votes
yes that fan should plug into the 4 pin MOLEX off the PSU.
Hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NEW ULTA V Series 350w power supply .:
I don't want to Accept this solution
Can you Help with these PC Cases problems?
NZXT NEMESIS ATX Mid-Tower Case
i installed mostly everything but it turns on for 2 second...
PC Cases
I have lost the product key of this software as my...
PC Cases
hi i have a nokia dbox but it has gone off
PC Cases
I Have a Compaq Presario SG3153Il PC which has only one...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
