Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Toshiba 42H82 problem
When I turn my television I get the following type of image:
The picture gets better slowly and after about 35-45 minutes the picture is better. This problem first started a few months ago, but the time for the picture clearing up keeps getting longer. This problem happens on all inputs. This television was purchased new in July 2003. Is it cost effective to repair this or purchase a new television? Thank you for any assistance.
  • mikea115 Feb 11, 2008
    My Toshiba has the same problem, when first turning on the TV my screen looks exactly like yours. It used to clear up after it warmed up but now its getting worse. Anybody have a solution?
Bad capacitors on the hyper module. there are 11 surface mount capacitors that need to be replace and that should fix it. the caps themselves only cost around $14 for all of them together
Posted on Jul 23, 2012
I had this problem (see my post above). Our local Toshiba repair shop fixed it for $33.00 in parts. My bill says "replaced capacitors in MVPU14 hyper module". Whatever he did it's working now.
Posted on Mar 28, 2008
I have the same problem, and don't have a solution yet; however, if you "split screen" on the remote control, you should be able to see one of the screens very clear.
Posted on Mar 24, 2008
Ynot 27:
your tv has this problem may be you need to check the cool solder or loose soldering of the components near the high tension voltage area.
from ahmantan
Posted on Mar 18, 2008
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it...
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Dec 15, 2011 | Toshiba 42H82 42" Rear Projection...
I'm getting a red outline on people's silhouette. Also getting a double image on printed words on my picture.
Look on your Convergence board the one that has your STK iCs STK392-110s their should be 6 resistors all 1.8 ohms Mats Elctronics has Parts for this TV 1-800-628-1118 more then likely you have a bad resistor that controls the red.
Jul 02, 2010 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82, no sound after fixing hyperboard.
Search for the audio amplifier - it's a chip with a radiator on it - the jack for the speakers should be close by.
Jan 09, 2010 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 - "broken" picture
the "scan converter module" is located directly behind the board where your inputs are in the back of the set. That should repair the problem.
Jan 08, 2009 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 convergence resistor and pico locations
yes better.  you need schmatic. servicemanuals.net.
Dec 13, 2008 | Toshiba 42H81 42" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42h82 no sound
Are you using a Cable Box?Using HDMI? Need more Info........
Jul 19, 2007 | Toshiba 42H82 42" Rear Projection...
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
867 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
