Bosch Axxis WFL 2060 Front Load Washer
Problem for Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF 2001 has finished a wash cycle but the
By jagkelly on Nov 06, 2009
Bosch WFF 2001 has finished a wash cycle but the water will not drain or spin away, cannot open the door. There is no apparent filter trap to empty, help!
Clarification Request
Posted by IRC2000 on Nov 18, 2009
When initially installed the plumber did fully not punch-out the drain hole in the plastic u pipe so it very easily clogs and forces the water pump to shutdown due to back pressure. Remove the drain hose and **** the hole out with a large drill bit then re-attach the drain hose.
Best Solution
posted on Nov 06, 2009
Very Helpful)
57 varieties
Rank: Guru  Bosch Washers & Dryers  Expert
Rating: 88%, 526 votes
Do the following.
  1. Switch off the machine, unplug or disconnect the mains power to the machine and turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Bosch Axxis WFL 2060 Front
Questions and Unsolved Problems for Bosch Axxis WFL 2060 Front
Do you recommend Bosch Axxis WFL 2060 Front Load Washer?
Answer
Answer
Is there a way to stop the beep on my washing after a cycle completes?
Answer
tear in the gasket, rust under the lip, not sure whether to grind off the rust and repaint or... (More)
Answer
what do the symbols (* or l, ll )on the detergent dispenser mean?
Answer
front plastic of door is falling off, runs fine without but want to reconnect?
Answer
Washer doesn't complete cycles. Stops with time still on the timer. Will indicate time indefinately... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch Axxis WFL 2060 Front...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14848
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
