I have a cub cadet riding mower LT 1018 with a 18.5 hp ohv briggs & stration. was cutting and there was a loud pow (pop) sound and the motor quit and will not turn at all not even by hand. the starter works find i took it lose and turned the switch and it spined good. there was and still is oil in the motor and none has leaked out
Unfortunately it sounds like you threw a connecting rod in other words a blown motor. The connecting rod has become disconnected from the crankshft and is jammed up between the case and the crank itself, the engine must be dissasembled and rebiult.
www.georgiamower.com/cub-cadet-ltx-1046kw-2014 The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Cub Cadet has five models in their new Series 1000 lawn tractors, all
powered by Kohler engines. Cub Cadet models -- as several other lawn
equipment brands -- are manufactured by MTD Products.
The Cub
Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an
aluminum block and cast-iron sleeve for longer life. It has a
full-pressure lubrication system with spin-on oil filter for easier
maintenance. This engine is not as powerful or as long lasting as the
Kohler V-Twin OHV, which is available in other models in the line, but
the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the
engine and provides sufficient grip to cut grass on moderate inclines.
Power is transferred from the engine to the transmission by a heavy-duty
Kevlar belt rather than a more expensive shaft drive. A Kevlar belt
also drives the three cutting blades.
The mowing deck cuts a
swath of grass 46 inches wide at one pass, and is removable for service
and cleaning. Four anti-scalping wheels help keep the deck from scalping
grass on uneven ground. The cutting height is manually adjusted from
1-1/2 to 4 inches. The turning radius is 18 inches, which standard for
lawn tractors. This model is intended for use on 1- to 2-acre lawns
without many turns or small obstacles.
Straight 30 weight oil (SAE 30). If it is a Briggs & Stratton, should take about 2 qts to fill. You can also use synthetic, 5w-30 in colder weather (40°F and below) or 10w30 for 40°F and above.
