Question about Intel Motherboard
Dead mother board
After the main current failed and returned, my pc went dead, I checked but no way, the power supply works fine, but my intel main board d915gux is dead, what might be the problem?
  • 110 Answers
The problem with power surges, or low power (brownouts) causing excessive current draw can cause multiple problems to motherboards. Even if you were to pinpoint and repair one problem that appeared to fix the fault, several other components on the board may have been weakened, and prone to fail.
If you are certain that the power supply is 100% ok, then replace the MB.
The best power protection is to use a UPS.
Posted on Jan 05, 2008
Cpu fan not working
Get a new one. They fail occasionally. The system cannot operate without it.
Jan 08, 2012 | Compaq Computers & Internet
My mother is dead no display
You must have meant MOTHER BOARD . but if there is no display then it is possible that the main powerr supply hasa failed. So check this SMPS unit before you can think that the mother board/display panel is faulty ONLY if there is correct voltage supply to the board.
Jul 14, 2011 | Computers & Internet
HP D7-1245DX Motherboard part number 506124-001 Power supply went bad, was running fine off of battery until battery went dead. Replaced power supply with good HP 463958-001 power supply, but it will...
I would first double-check the "known good" power supply. If there is something bad wrong with the MB, it could have blown the fuse in the power supply. I have seen very few fuses on motherboards, they are normally in the power supply. If the power supply checks out OK, then double check the connectors between the power supply and the MB.
Oct 02, 2017 | HEWLETT-PACKARD Hewlett Packard 506124-001...
I have a sylvania LC200SL8 which went dead. Repair shop said it needed a new "Mother Board" (pn A7140UH) which I replaced. Still does not work at all. Any suggestions?
Power supply voltage outputs should be check first before anyhting else is replaced. I see that it has one main board which has the tuner, inverter, power supply all in one. What do get right now?
Oct 14, 2010 | Sylvania LC-200SL9 20 in. LCD EDTV
My dell percision 470 is dead. Don't know if I need a new power supply or motherboard. Dave Moll
you can check the power supply by voltmeter if it works then may be mother board is dead
Aug 18, 2010 | Dell Motherboard For Precision 470...
I have a emachine PC. PowerSupply blew up. changed it still down
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
Jul 08, 2008 | Intel D845GVSR Motherboard
Sharp ER3110
Does the device do anything? Is it completely dead? If it is, then there is a good chance the power supplies have failed. Power supplies use electrical devices called "capacitors" to filter out voltage variations which are created during the process of converting alternating current to direct current. If the capacitors have shorted out, they should have caused a fuse to blow.
Do yu have the manual for the machine?
Mar 10, 2008 | Computers & Internet
New Problem
The manual you need will be on the board manufacturers web page, howevr I will bet you have the case power switch and perhaps the reset switch on the wrong pins on the mother board. To check this, remove the switch leads from the mother board, then use a small screw driver and bridge the pins on the mother board a pair at a time. All of these leads plug on to the board in a line and not across the two lines of pins. when you get the mother board to fire up by this method geet a torch and look closely alongside the pins you will see the letters PWR SW or RS SW. It does not matter what polarity these two sets of leads are plugged onto both will work. The LED lights on the case front will only work if the polarity is correct but it will not do any harm if they are backwords. On the board you should se two sets of pins marked HDD and PWR these are the led light pins you will know you have them right when the usual red and green lights are working at the front of your tower. Regards mistyman
Aug 15, 2007 | Balance CP4401 PC Desktop
System will not power up
Have you replaced the cmos battery(disc shaed flat 3V CR2032), although there could be more sinister problems than this as the mobo or processor may be damaged.
Feb 12, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel Motherboard Logo
100 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
