Casablanca Fan 3245T Ceiling
Ceiling fan
posted by TRICIA6790 on Jan 05, 2008
i have purchased a ceiling fan from b&q and having problems wiring it. the light works but the fan does not could you please help and give me detailed wiring instructions to solve this problem
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 07, 2008
Helpful (85)
dolphin522
Rank:Apprentice Apprentice
Rating: 85%, 3 votes
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ceiling fan:
I don't want to Accept this solution
Can you Help with these Electric Fans problems?
I have 3 ceiling fans in my home. I recently tested and...
I have a Casablanca Mission fan which on the second day...
Fan is on high speed and I cannot get it lower
light kit does not fit ceiling fan
Are there any ceiling fans that run on batteries?It sounds...
Loading problems.
Repair Service
Find Electric Fan Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
