janaire why not wrap the fuse in aluminum foil? Then the errant part can be identified by the faint red glow. DO NOT bypass your fuse or overfuse the device!!!
Lou
try to make a jamper on the fuse, tie around on the fuse 3 wires just a size of a hair , just enough to cut off when same thing happen again on the drill.
Was this helpful?
Yes
No
Popular Solutions for Coleman Cable Coleman 18 Volt
My recip saw just quite working I was cutting and stop to move and it didnt work when I pulled the...
(More)
My recip saw just quite working I was cutting and stop to move and it didnt work when I pulled the trigger is it the trigger I never had a problem B-4
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package...
(More)
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon. Good luck!
