if you set the spool down into the case and have the springs attached to the case and the other end to the spool but the rope shouldn't be totally wrapped around the spool. Leave about 8 inches of rope where you can grasp it. There is a small slot cut in the spool where the rope coming from the spool can ride it. That will let you wind the spool tighter and tighter. When you have about 5 or 6 turns of the spool, position the slot in the spool even with where the pull rope enters the case. Pull the excess 8 inches of rope back out through the slot till all the rope is outside the case or wrapped on teh spool. It should now wind it all back in. You might have to adjust the 5 or 6 turns of the spool as different saws have different lengths of rope and different size springs.
Was this helpful?
Yes
No
Popular Solutions for Poulan Wild Thing 2375 18" Gas
how to change the spline that holds the sprocket and clutch assembly together on a poulan wildcat...
(More)
how to change the spline that holds the sprocket and clutch assembly together on a poulan wildcat with a 18 inch bar
My Makita Generator, Starts but wont run for long. It appears there is a part missing on outlet from...
(More)
My Makita Generator, Starts but wont run for long. It appears there is a part missing on outlet from Carby? Ned to look at a manual drawing to see what is needed to fix it.
