Question about Mitsubishi WS-55807 TV
Mitsubishi HD 1080 Diamond distortion
Recently we hooked up a DVR and High Definition cable box. Now there is a distortion where the picture is distorted and bows inward from the top and bottom. The image is also stretched at times. Sometimes, it also has lines going thru the image. It happens with regular tv, a DVD, etc.
  • 1 more comment
  • brookmiller Nov 26, 2008
  • johnvanv Jan 26, 2009
    I have the same issue and noticed the Blue convergance would not adjust the red works fine but the blue will not move one bit and the auto Convergance does no good
  • hengung0889 Jan 30, 2009
  • 25 Answers
IT MAY BE YOU DID NOT READ THE ORGINAL INSTRUCTIONS.iN THE MANUAL IT SAYS ON EVERY 3 PAGES NOT TO HAVE BLACK BORDERS ON MORE THEN 15% OF THE TIME.iT DOES NOT SAY WHY BUIT i BELEIVE ITS BECAUSE OF THE UNEVEN HEATING OF THE
MIRROR,TRY TO STRETCH THE SCREEN OR THERE IS AND ADJUSTMENT TO USE SEVERAL
COLORS (BEST GRAY) TO FILL IN THE 3-4 ON A 9-16 SCREEN IF YOU HAVE NOT BEEN DOING THIS FOR YEARs ,to bad so said TRY TO CONVERGE AS BEST AS POSSABLE AT THIS POINT,IF YOUR NEXT t_v BOOK SAYS TO DO THE SAME THING AT THE sTART OF EVERY CHAPTER ,WITH A WARNING ASK SOMONE TO READ TO YOU.;
Posted on Feb 06, 2009
    Genius:
  • 1,153 Answers
For more info ctechnicians.com
Posted on Jan 05, 2008
This dvd recorder worked PERFECTLY when I had digatal cable. As soon as I up graded to HD with a HD box from comcast, I cannot get the recorder to record anything. I hooked it up the same way as I did with...
The HD box from your cable company only sends High Definition Video signal which DVD does not support. Your DVD recorder "CANNOT RECORD THIS PICTURE" because it can not process (see) the High Definition (HD) Signal.
To record from an HD reviver you would need a HD recorder (Blu-ray) very expensive The standard practice for recording from a HD cable receiver id to use an DVR here is a link to one for about $100 some models will have a standard video output you could connect your dvd recorder to.
http://www.google.com/products/catalog?q=HD+Dvr&oe=utf-8&client=firefox-a&hl=en&cid=15241578777457062393&ei=puGPTNuoFIm4iwSJ2s1h&sa=title&ved=0CBcQ8wIwATgA#p
Sep 14, 2010 | Sony RDR-GX330
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I cant get high def 1080-i to work on my mitsubishi 55807
IYou have to have your comcast box tuned to a channel that is broadcast in HD. On your Comcast remote hit menu. This will bring up several icons, one is HD. Select that icon and it will bring up the TV Guide for just HD channels. Select one and tune to that channel. Once your on that channel use your original remote and hit menu, then advance features, then go down to video display and change it from 480 to 980 or 1080. Let me know if this helps.
Dec 15, 2008 | Mitsubishi WS-55807 TV
Concaved distorted picture in 1080 Mitsubishi 65" TV.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
Dan
Dec 11, 2008 | Mitsubishi WS-55807 TV
No color on mitsubishi 1080
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Oct 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Connection of HD TV Issues
hdmi cables u need also set moterol box out to 1080 i if it can or 720 p ok use hd antenna for locals in hd also
Jan 10, 2008 | Audio Players & Recorders
Mitsubishi WS-55807 TV Logo
471 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
