LG RH266 Recorder
Problem for LG RH266 Recorder
Recording problem with LG RH266 Recorder..
By AldoronRay on Jan 05, 2008
Hi there all, i have a small problem with my LG RH266 Recorder. I can't record from my HDD to a DVD? I have tried several new dvd disk's, all kind of brands (dvd-r, dvd-rw) and none works, everytime i wanne record from HDD to DVD i see is "replace recording disk", has anyone a selution for this?
Same Problem
Mar 11, 2009
-   I have had this problem on the same unit and have had to send it back twice for repair, fortunately it has a 3 year warranty-   Guest
Feb 16, 2009
-   I have the same problem-   Guest
Mar 26, 2008
-   I have tried using DVD+R and DVD-R Kodak discs and it keeps telling me to change the recordable disc.
Anyone have a solution???
-   Guest
Jan 09, 2008
-   Hi,
I also have problems recording form the HDD to a disc. I have tried many different makes of disc but cannot even get the machine to recognise them it keeps asking me to insert a recordable disc.The machine will not format a disc as it cannot recognise ther is one there.
Can anyone recommend a specific brand of disc that will work or help me with the problem.
Thanks,
Paul-   Paul555
Best Solution
posted on Apr 19, 2008
Very Helpful)
aewins
Rank: Apprentice
Rating: 100%, 5 votes
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Jan 05, 2008
Very Helpful)
spare_head_2
Rank: Wiz
Rating: 75%, 44 votes
Hi AldoronRay,
The recordings you've made on the HDD are they of standard definition TV broadcasts (SDTV) or transferred from copyrighted DVD sources? If they are coy-protected they will not record, if the size of the recording exceeds the DVD's capacity it will ask for a media with greater capacity, such as a Dual-Layer DVD. Ensure that your recordings do no exceed 4.3GB and it should work okay. I'd be surprised if the unit did no warn you, but then again it depends on how lazy the design engineers have been.
I could not find the exact manual for this on line but, I didn't search for very long.
Try to transfer a small clip of 5 minutes standard definition TV. If that fails it's probably a faulty unit and you need to get it exchanged or repaired. Depending upon were you live LG have a fairly inexpensive telephone support service who can guide you through some simple tests to determine if it's a faulty unit. They can also tell you were your nearest service centre is located.
Hope this is helpful.
Regards,
Spare head 2.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG RH266 Recorder
Questions and Unsolved Problems for LG RH266 Recorder
Do you recommend LG RH266 Recorder?
Answer
Answer
how do i finalize disc i burn from my hard disc?
Answer
how do you set the soft keys on this phone?
Answer
LG DR 165 Auto programing stops after finding one station only
Answer
After trying to tune the DVD player/recorder the picture is full of horizontal lines and the sound... (More)
Answer
lg rh266 dvd 160gb keeps ejecting dvds thus making them unusable
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in Lancaster, PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
