HP Color LaserJet 2600n Printer
Problem for HP Color LaserJet 2600n Printer
We have a HP Colour Laser Jet 3600n. We have
By teresa527 on Nov 06, 2009
We have a HP Colour Laser Jet 3600n. We have recently installed re-manufactured print cartridges. Our print quality has been badly affected. Whilst black printing is still of high quality, colour printing is badly shadowed and almost unreadable in places. Is there any maintenance we can do to improve this?
Comments:
Nov 06, 2009
- Having printed squares of each colour - there is no lines, markings or fadings on any of them. If anything it is worst on the black and clear pages, and just down the right hand margin! Any more ideas?
Best Solution
posted on Nov 06, 2009
Helpful)
Soulvisitor
Rank: Guru  HP Computer Hardware  Expert
Rating: 88%, 2350 votes
nope...... the problem as you rightly poit out is the cartridges, most refills are poor quality and dont last, but the real ones are expensive but very rarely cause issues. If one colour is dodgy the entire colour process fails, print a square of each colour to determine which colour cart is the issue and complain to seller, 99.9% of print quality issues with these HP's is due to non gen toner....not much you can do, expensive is colour printer fullstop.
Comments:
Nov 07, 2009
- Hi Teresa,
On these HP's you can print a colour alignment page, it may be hold tick while power up or via the printers operations panel print alignmet/status page, anyway once you get the page in the corners is a alignment picture, there is on a good working unit 4 thin lines each colour equal distance apart, if these are not align properely it can cause issues that sounds like yours, ie squres are good but colour print bad (shadow effect) ....
Can you print me this page, what are yours like?
You can also check the transfer belt that it is not torn, ripped or damaged..dont wipe it;) It is the unit that has a long belt attached to inside front door and opens when door does....can be removed two buttons either side near front door hinge.
I'm now guessing your alignments out, normally this is cartridge related but not always, first I normally fit 4x HP gen carts to confirm... I have found on occasion the fault not being the carts or a damaged belt but a dirty static strip...
These static strips are either on your model or the 2600, but you can check yours by looking with front open.. above top black cart, near level with the front of such but higher towards the top, it is just a mental bar running width of printer with teeth ie VVVVVVVVVVVV if its there on it is green slider, move it up and down, or clean VVVVVVV with a brush...
The most economical, reliable, full colour laser is the Kyocera range, take out extentend warrany and length of warranty is life of any modern machine..More expensive to buy, but chepest to run..thats where your money goes....Kyocera stuff is made to work unlike most, no drums, no fusers, no nothing to do to it but feed quality toner, no cartridgess at all, any other colour laser is going to cost you more, promise..p.s. I dont work for any one brand but know them true!!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you - we were hoping for a less expensive solution, but think we knew this at the back of our minds. " - teresa527
Popular Solutions for HP Color LaserJet 2600n
Questions and Unsolved Problems for HP Color LaserJet 2600n
Do you recommend HP Color LaserJet 2600n Printer?
Answer
Answer
When printing colour reds come out a feint orange colour instead of a bright red. It has slowly... (More)
Answer
HP Color laserje 2600n only black print is commong no one color is printing, replace all the CMYK... (More)
Answer
magenta very pale. I have put a new cartridge in.
Answer
When I print a page with color across the entire width of the page, the colors on the left hand side... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Color LaserJet 2600n...:
Top Printer Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
