Question about Canon PIXMA iP3000 InkJet Photo Printer
Ink has run out!
What should I do? I refill my cartridge, but the printer still dont work...please help
Reset the printer: press for 5-8 seconds the button near the turn on/off button...
Posted on Jan 05, 2008
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl
The error code you are seeing may or may not have to do with the cartridges being refilled.
Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems.
QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source
Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray
I found the above article interesting and genuine.
To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product.
Perhaps you will find the following document helpful:
HP Printers Problem with Printhead Printer Failure Ink System Failure or...
I hope this helps.
I work on behalf of HP.
Jun 23, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
I dont know how to refill the ink of my printer please help me iP1980
How To Refill Ink In Printer Cartridges – Video Instructions
Inkjet toner refill - Beware: Non-original Toners Can Cost 31% More Than Original HP! www.HP.com/IN/Toner Stop Check Fraud Now - Prevent Check Fraud with Source Technologies MICR Printers! www.SourceTech.com This video illustrates the various steps required to refill printer cartridges at home using disposable syringe and a bottle of printer ink.
Jan 29, 2010 | Office Equipment & Supplies
Esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Jul 26, 2009 | Kodak ESP 5 Printer
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
I refilled a 33 colour cartridge still says low
I would like to inform you that Lexmark printers does not support refilled cartridges. Please note that #33 cartridge is know as a rushmore cartridge and in this cartridge it has memory chip on it to identifiy the ink estimation. hence it is not possible to change the low ink indication.
Please note: using refilled cartridge may void ur printer warranty.
Apr 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Won't print with refilled cartridges
Hi..
First of all you should not use a refilled cartridge as its not good for long run...the ink sensor got damaged and needs replcement...and please dont tell lexmark about this if the machine is under warranty ...they wont help you other wise.
Regards,
debroy
Nov 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
