If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in this part is the usual
reason that a dishwasher doesn't drain. Remove the drain line to clear
any debris from the hose or hose connection at the household drain line
connection. Reattach the hose before starting the dishwasher again.
Pump You can reach the pump from inside the
dishwasher. Remove the lower rack, spray arm and support. Look for an
impeller, a device that spins around and forces water through the spray
arm. This is the wash impeller and beneath it is the drain impeller
that pushes the water into the drain port. Replace it if found
defective or worn out.
Drain valve/solenoid The drain valve may have a
solenoid with lever that sticks or frozen and prevents the dishwasher
from draining. Free up the solenoid and lubricate the lever.
Belt A certain brand of dishwasher uses a belt
to drive the pump. Replace it if broken or worn out.
Motor Check it if turning or working.Turn the rotor
manually to see if stuck and free it up. Replace if defective, it is
not serviceable.
Was this helpful?
Yes
No
Popular Solutions for Bosch Classixx WVF 2402 Front
Bosch Classixx WVF 2402 Front Load All-in-One Washer / Dryer
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
