Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so. When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management. Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy. You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs). Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management. Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Was this helpful?
Yes
No
Popular Solutions for SanDisk 2GB Cruzer Micro USB
when playing the video off my sd card from my camcorder on the computer, i have no sound. why is...
(More)
when playing the video off my sd card from my camcorder on the computer, i have no sound. why is this, and how do i fix it ?
how do you know when info is on how do you get it on other computer can you do this without internet...
(More)
how do you know when info is on how do you get it on other computer can you do this without internet need manual help have sandisk cruzer micro 1.0 GB
how do I download music from computer to sandisk 4gb flash driver. I need how to download music free...
(More)
how do I download music from computer to sandisk 4gb flash driver. I need how to download music free and record to this device. I promised a friend and don't want to look foolish
When I plug my flashdrive in it wont recongnize it and it wont even light up anymore. It just worked...
(More)
When I plug my flashdrive in it wont recongnize it and it wont even light up anymore. It just worked the other day and now it doesn't! Whats wrong? Please help all of my school work is on it!!
