Hi i have a hotpoint aquarius condenser tumble dryer and it turns round blows air and makes all the right actions of a working tumble dryer but it only blows cold air an will not dry clothes could you please help
I had same problem.At the bottom of the dryer is a panel that pulls down.Located behind that is a vent box,held in by 2 plastic clips.Unclip the box and pull out.Yours should be completly blocked with fabric and fibres,as mine was.All you have to do is take the top section off exsposing the vents,take it out in the garden,and get a hospipe with a gun on the end,then shoot jets of water down the vents to clear all the grim.Once you have done this ,shake off excess water and replace.Your tumble dryer should heat up now,if it doesnt you need new thermostat
after selecting wash and startingthe machine fills with water then stops and all the led lights...
(More)
after selecting wash and startingthe machine fills with water then stops and all the led lights flash,the only way to stop this is to pull the plug. the machne is a hotpoint aqualtis aq9luv
my dryer is not working on my aquarius wd440 there is a pink wire attached to a coonector and the...
(More)
my dryer is not working on my aquarius wd440 there is a pink wire attached to a coonector and the othe end seems to have been connected to a brown wire i think it looks like it has snapped could this be the problem/
