Question about Kenmore 98702 Stacked Washer/Dryer
Cant release top panel
Its actually an older model kenmore, but looks same ten years old.
I released front clips, took panel off which exposes back of the top.
see 2 flat spring type clamps which come from the back and lie flat on the top. they are reccesed in two slots on top.
Beside each of these fastners there is a bolt head showing.
Do these have to be loosen these or do I snap the springs off.
Trying to get the front panel off eventually to check for leak
  • 46 Answers
If you are talking about the springs that look triangular in shape you use a putty knife or small flat screw driver and push the spring inwards. the top of washer will pop up. repeat with other spring. top will lift up now.
Posted on Jan 29, 2008
6ya staff
SOURCE:
I have kenmore 110.26912690 washer. I want to remove and replace the water intake valve and it seems I nearly need to take the whole machine apart. Is this so? can you send me the how to get it out and...
The washer comes apart very easily. Problem is how the control panel is released. Either there is two screws in the front or rear of the control panel once these are removed the panel pulls forward and leans back. On some models there is two clips under the front edges of the panel which have to be depressed with a putty knife. On some models the end caps on the control panel pry off exposing the screws. After leaning back the control panel you must un-plug the lid switch, remove two brass coloured clips holding the case to the rear panel by prying with a screw driver, lean the case forward and remove the case.
Feb 26, 2011 | Kenmore 24042 Top Load Washer
Dropped steel wool pad between tub and front panel
If the model number is correct, take a putty knife and insert it along the front seam where the top panel meets the front panel. There is a retaining clip about two inches in from each side. Push in with the putty knife while lifting on the top panel to release each side. Once released, the top panel will lift up exposing the screws that hold the front panel in place. If you have questions about any of these procedures, or require additional assistance, please post back and let me know. I hope this helps you.
Jul 25, 2010 | Maytag PAV2300 Top Load Washer
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
How do I get the panel off to look at the motor?
Hello there
Can you please give me a model number so i can send you the repair information that you will need
Best regards mike
Jan 02, 2010 | Kenmore Washing Machines
Getting off the End Caps
The end caps do not come off on this type of control panel. There is a retaining clip holding it in place at each front corner. You need to insert a putty knife between the top panel and control panel at the left and right front corners. Push the knife straight in from the front and push to release the retaining clips while lifting the panel. Once both clips ar released, the panel will open up. You can view a diagram of the console at searspartdirect.com. Just type in your model number and look under the "Control Panel Parts" heading. The retaining clips are listed as item number 8.
NOTE: Sometimes the clips will come off and fall down inside the washer cabinet. If this happens, you may be able to retrieve the clip by moving the washer and looking underneath. However, if it becomes caught somewhere inside the cabinet, you will need to remove the exterior cabinet to retrieve it. Just follow these steps:
1. Unplug washing machine.
2. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
3. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
4. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console by aligning the retaining clips with the holes on the top panel and pushing straight down until you hear a "click".
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 18, 2009 | Washing Machines
I have model 110 24642300 top load. took the back
Actually the washer should have come apart by removing the outer casing while leaving the back in place on the frame. The following steps explain how to remove the casing and reinstall:
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
4. Reinstall console.
You may try going through these steps and make sure you have the back of the washer correctly in place on the frame prior to reinstalling the case. It may sound like a lot, but this is actually the proper (and easier) method.
If you have any questions, please let me know. I hope this helps you.
Jul 29, 2009 | Washing Machines
Drain pump broke on a MAV 5000 AW
To remove the front panel, take a putty knife and push it in the joint between the front and top panel close to the top corners ( both the left and right) . As you carefully push back, you'll be pushing back on the retainer clips that hold the top panel down.
This will get the top panel able to tip back, exposing the top screws to remove the front panel. Slide the front panel upward to release the lower retainers...
Should do it..
K
Mar 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I am haveing problem removing the front panel on my gas dryer?
the panel comes off using a putty knife to release some spring clips 6568d2d.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2009 | Kenmore 72802 Gas Dryer
Kenmore 80 series top loader leaks from the front. how to fix the problem
The water pump is the front and has probably failed.
To access it REMOVE POWER, lift the console by one of three ways. 1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward. 2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw. 3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling) or the shaft of the motor for rusting.
If the pump appears OK, inspect the drain hoses for splits or cracks and that the hose clamps are properly secured.
Jun 07, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer
the front panel is removed on this model for acess, pop the top up and back by using a putty knife or a thin ***** driver. theres (2) clips that will release the top a few inches in from each sid( push w/ tool and the will pop. tip lid back and there should be 2 screws to release hte front panle for better look. if your seeing brown oily splatters around inside oc cabinet that would be a transmission problem(10 year+ old machine not worth repair).never stated what problem with machine is though
Mar 11, 2008 | Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
