- What's happening? I just sent you the above clarification request, which you have immediately sent back. I've no idea why you've done this, but it's no help to me. Please write me a sensible, comprehensible, human-generated reply, or tell me there's nothing you can do to help me. Michael Mills.
Silly me. I thought the idea was that you offer rapid answers to simple questions! It's now more than 24 hours since I asked how to reduce the size of a document when photocopying it on my HP Photosmart. The only reply I've had is one saying you want to know if I've solved the problem yet. Of course I haven't! I'm not interested in a multiple-choice most-frequently-asked questions things. Please either answer my humble query efficiently, or tell me you can't and I'll ask someone who can.
Popular Solutions for HP Photosmart C4580 All-in-One
HP Photosmart C4580 All-in-One , Scanner, Copier InkJet...
Hello, i have inserted the cartridge below the actual slot i.e. in the base of the printer. Then i...
(More)(More)
Hello, i have inserted the cartridge below the actual slot i.e. in the base of the printer. Then i swithced on the printer and now the actual cartridge holder is above the cartridge in a jammed position, how do i remove the cartridge and correct the problem?
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
I set it up to print wireless about 8 months ago. To begin with it worked fine.
Then I started...
(More)(More)
Then I started getting the error message: There is a problem communicating with the printer. Make sure the printer is powered on.
Then another time it will say: Printer is currently off-line.
Some of the time I will take the laptop over to the printer and plug in the USB cord directly from the printer to the laptop and tell it to print. Once in a while it will work other times it will not.
Any ideas. I am using a MAC laptop.
Posted. Thank You!
after replacing the cartridges and realigning...tried to use adjust size with border or borderless...
(More)(More)
after replacing the cartridges and realigning...tried to use adjust size with border or borderless and Im unable. Shows up regular size or slightly larger
Posted. Thank You!
I hate this printer! Not only does it only work half the time wirelessly without me unplugging it...
(More)(More)
I hate this printer! Not only does it only work half the time wirelessly without me unplugging it before I print, but now the scanner won't work AT ALL. I I deleted all of my printers and downloaded a driver from HP, but now it won't even print anything. HELP
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
