Question about Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum
No suction..says bag full
I just changed the bag...properly and when I switch the vacuum ON..it reads bag full and has no suction. What have I done wrong?
  • Anonymous Mar 13, 2014
    I was using the vacuum. The bag was full. I put in a new bag. When I hit the on switch, the vacuum did not start.
You were right! Sure enough my problem was not a sock but a weird dried fig solid as a rock forming an obstruction that eventually enough lint built up that it formed a complete and total blockage. The fig was so tough that it almost pierced the hose. I went after it with a wire chase and once I noticed that it was about to pierce the hose in one place I managed to dislodge it with a counter twisting motion. Vacume on - Wooosh - Power and suction once again. Thanks I was about to go buy a new vacume!
Posted on Aug 07, 2008
  • 319 Answers
There is most likely an obstruction somewhere in the system that is not obvious to you. Please inspect all hoses. I have seen a sock in a vacuum line before, it caused these same symptoms.
Posted on Jan 05, 2008
Model No. 116.39110900
Remove the filter / bag from the compartment, close the cover and briefly turn on the vacuum - is there suction? If so, check that the bag isn't already full / or replace with a new bag. Make sure it the bag is not being pinched / caught under the cover.
If no suction, look closely at the edge of the filter / bag compartment opening of the vacuum. There should be a gasket that the cover presses against to help ensure a good seal. If this gasket is missing, cut, has an object lodged on it or is otherwise damaged - it may be preventing proper sealing of the door; allowing air to be pulled through the gap in the seal - and responsible for the loss of suction at the hose.
Oct 19, 2015 | Kenmore Vacuums
Hoover telios keeps saying bag full when its not
Something is plugged up making it sense there isn't vacuum and saying the bag is full
Jan 31, 2018 | Vacuums
Dust bag was full and have changed it but not getting proper suction since bag change - why?
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Feb 13, 2011 | Miele Revolution 600 Bagged Canister...
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Mar 05, 2008 | Vacuums
Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum Logo
118 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
