Question about Intel D865GBF Motherboard
Motherboard failure Motherboard Intel D864 GBF - when Power button is pressed ON it gets ON, fans rotate, but within 1 - 2 min it shuts off. Can you please help.
  • neelesh Jan 06, 2008
    Thanks for your help. The problem has been solved and was due to the Power Supply. When the output voltage from the SMPS were incorrect. Post replacement of the SMPS, the problem has been solved.
REMOVE PROCESSOR HEATSINK AND CLEAR DUST ON HEAT SINK AND ON PROCESSOR
Posted on Jan 05, 2008
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
My xps m1330 booths up stays on for like 20 to 30 mins. then shuts off. After it shut off if i press the power button it willbooth back up again but this time it will shut off in within 5 to 10 mins. I get...
Sounds like the fans need cleaned or replaced. If the board and or the processor get to hot they may actually throw an error code. Try cleaning it and making sure the fans are moving.
Aug 25, 2017 | Dell XPS M1530 Laptop
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
Show all solution to d945plrn motherboard problem not powering up
PSU IS OK? You're sure? You tested the 3 main voltages coming out?
DON'T rely on; "The LED lights are on, and the fans spin, so therefore the PSU must be good.
1) If ALL the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor uses 51 to 125 Watts of power.
With a Power Supply that has a weak voltage power rail, you will see LED's light, and fans spin; BUT not enough power to turn the Processor on.
Power Supply also needs to be plugged into motherboard to test, because you need a Load on the Power Supply.
PSU is KNOWN to be good? I mean KNOWN.
Not, "It's brand new so I know it has to be good"
Okay, moving on.
CPU OK?
How did you test it? Install on another working motherboard?
Are the Electrolytic Capacitors on the motherboard good?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors on the motherboard are used as Filters, and Voltage Regulators.
The ones used as Voltage Regulators are in the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Part of what the Motherboard Voltage Regulator Circuit does, is to regulate voltage for the Processor. (CPU)
The CPU MUST have a steady, 'clean', supply of voltage, and it MUST be kept within the Processor's voltage tolerance range.
Too much, or too little, and the CPU shuts off. BIOS turns it off.
(CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
I know you are aware, just posting for all those who read the solution in the future)
http://downloadmirror.intel.com/15140/eng/D945PLRN_ProductGuide02_English.pdf
[Better motherboard due to the Intel Q965 motherboard chipset,
http://www.ebay.com/itm/INTEL-DQ965GF-CORE-2-DUO-LGA775-SOCKET-P-4-MOTHERBOARD-I-O-FACEPLATE-INCLUDED-/290863623024?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D5685984037376928917%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D330632928551%26
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to Q965 in left column ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Intel D945PLRN Motherboard
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
K8mc51g motherboard wont turn on i shut it down and now it wont power on i tried reset jumpers and removing the battery for 30 sec and taking away all power for 24 hours
If after pressing power button the fan rotates ...then the BIOS might have been corrupt ...and if the fan dont rotate then the SMPS might have fault
Oct 21, 2009 | E-Machines eMachines Desktop PC
INTEL 865 GBF TURN ON PROBLEM
You know the problem HDD. Why not try another HDD?
Good luck
Feb 23, 2008 | Intel D865GBF Motherboard
Not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
Nov 29, 2007 | Intel Motherboard
Intel Mother Board D845WN
Seems there is a loose wire, loose card, motherboard failure or mis-plugged wire. IS everything in right?
Nov 09, 2007 | Intel Desktop Board D845WN Motherboard
Is the auto power save function employed?
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Intel D865GBF Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
